Old 05-27-2009, 08:35 AM   #1
Juan_Mitosis
Juan_Mitosis's Avatar
Send a message via MSN to Juan_Mitosis
Default Accord 91 Fuse box diagram
I have searched,and cannot quite find the diagram for the fusebox of an Accord LX Sedan 91, the fuse box thats inside the car. There are a bunch of blown fuses, previous owner was retarded, and I need the diagram so I can replace with the correct fuses. Thanks in advanced!
Juan_Mitosis is offline   Reply With Quote
Old 05-27-2009, 12:12 PM   #2
dafang
1991 Honda Accord
Default Re: Accord 91 Fuse box diagram
Diagram attached, this is for a 92, but should be the same as a 91
1991 Accord EX Coupe MT-5
dafang is offline   Reply With Quote
Old 05-27-2009, 12:55 PM   #3
Juan_Mitosis
Wow!! Thanks man! Do you also happen to have the fuse box diagram for the one thats under the hood? =D
Old 05-27-2009, 02:30 PM   #4
dafang
1991 Honda Accord
Under Hood fuses
Old 05-30-2011, 01:16 AM   #5
vinsanity
Icon3 Re: Accord 91 Fuse box diagram
Thank you soooooooooo much. I do hope that it helps me, if not thank you for at least helping. Went tyo the dealer and they waNTED TO CHARGE ME 160.00. THANKS FOR THIS WEBSITE
vinsanity is offline   Reply With Quote
Old 05-30-2011, 06:59 AM   #6
boat49
Exactly what I was looking for too! In my short time on this site I have found alot of information that I couldnt find anywhere else........Great site!!
boat49 is offline   Reply With Quote
Old 06-25-2011, 02:46 PM   #7
gaby21
I Have A 1991 Honda Accord Dx..My Dashboard lights and tailight are out ..I replaced the fuse and it keeps on blowing..I have no clue were to begin to look for the short..can you help me please
gaby21 is offline   Reply With Quote
Old 06-25-2011, 05:22 PM   #8
dafang
1991 Honda Accord
I would start by removing all the bulbs, checking that the bulbs are OK, checking the sockets for any sign of damage. checking for any damaged wire at the sockets.
Old 02-10-2012, 04:21 PM   #9
blk91accord
sorry for hijacking the thread but I have a similar problem on a 91accord except mine does not even crank, no dash lights, no headlights, all fuses checked, alternator tested battery is new.
The weird thing is there must be a short somewhere because the battery voltage read 9V a week after it stopped working, I tried to started then the voltage dropped to 2V-3V, but if I disconnect the battery, then the voltage starts climbing up to 6V.
Any ideas?
blk91accord is offline   Reply With Quote
Old 02-11-2012, 06:39 AM   #10
Lost Again
Any ideas?
Take the battery to a parts store and have it tested, based upon your description, be prepared to buy a new battery.....
My child arrived just the other day; he came to the world in the usual way
I can explian it to you, I CANNOT understand it for you
Lost Again is offline   Reply With Quote
Old 08-05-2013, 11:25 AM   #11
FrankyLee
Hey to everyone, I just joined the forum.
I was wondering if a blown fuse would cause my door mechanism to fail...I canʻt open the driverside door. The locks work but the door canʻt be opened from inside or out.
I had a mechanic look at it and he was not able to find a reason for it, told me it may be an electrical box inside the door. Itʻs not the clip that attaches to the door handle inside the door - already checked that.
The box is hard to get to as they have to dismantle the door from the inside and itʻs a lengthy and costly job. So I wondered if it could be a fuse that goes to that electrical box inside the door.
I dunno what Iʻm talking about...just what Iʻve been told.
Anyone have any ideas if there is a fuse that would go to the door that would help this? The headlights-on warning does not sound when I get out of the passenger side so it may make some sense that the electrical box in the door and lights-on are connected with a fuse.
Thanks!
FrankyLee is offline   Reply With Quote
Old 08-06-2013, 08:30 AM   #12
Lost Again
Sound more like an issue with the door latch.
http://techauto.awardspace.com/doorproblem.html#latch
Old 08-07-2013, 06:37 AM   #13
FrankyLee
Thatʻs what I thought but when I checked and 2 mechanics checked, it was not the door latch. Thatʻs when they both suggested it might be the "electrical box" in the door.
Itʻs a lengthy job to remove the whole door panel from the inside to repair that box, thatʻs why Iʻm looking around some more and wondered if it might be the fuses. The fuse cover and picker is missing in my car so I ended up here.
Thanks!
Old 08-09-2013, 08:16 AM   #14
Lost Again
Thanks!
Good luck to you then.
I'll give you just one thing to think about. With the battery out of the car, the door will still open and close......hummm, think on that for a while.
1990, 1991, 2002, 2006, 91, 92, accord, box, civic, crx, diagram, fuse, fuses, honda, image
