car shakes a lot and wastes alot of gas?
Old 05-19-2009, 10:19 PM
EGlove23's Avatar
Icon2 car shakes a lot and wastes alot of gas?
my car shakes alot and it wastes a lot of gas.....i have a d15 non v-tec ingine and it shouldnt waste thet much gas.....anyone help me out!! thanks =D
EGlove23 is offline
Old 05-19-2009, 10:20 PM
geneeunit's Avatar
Default Re: car shakes a lot and wastes alot of gas?
Originally Posted by EGlove23
my car shakes alot and it wastes a lot of gas.....i have a d15 non vtec engine and it shouldn't waste that much gas.....anyone help me out!! thanks =D
what kind of car? original motor? swap? mileage of motor?
do you have a check engine light?
whats your mpg averaging?
geneeunit is offline
Old 05-19-2009, 10:26 PM
EGlove23's Avatar
ITS A 94 HB EG....AND HAD ORIGINAL MOTOR...THE MILEAGE IS ABOUT 150...NO CHECK INGINE LIGHT.......IDK THE MPG
EGlove23 is offline
Old 05-19-2009, 10:30 PM
geneeunit's Avatar
any broken motor mounts? automatic? manual?
and how do you know its wasting gas if you're not keeping track of the mileage?
also, your driving habits will affect your mileage the most.
Old 05-19-2009, 10:36 PM
twiztid_989's Avatar
my eg9 does the same thing
twiztid_989 is offline
Old 05-19-2009, 10:37 PM
EGlove23's Avatar
ITS MANUAL....NO BROKEN MOTOR MOUNTS.....
I DRIVE A NORMAL AS I CAN....I COULD FULL IT UP WITH GAS...AND USE IT AND THE NEXT DAY ILL HAV 1/4 GONE.....OF MY TANK....IT FEELS LIKE I DONT USE MY CAR AS MUCH TO BE WASTIN DAT MUCH GAS? AND WHY DO U THINK THE SHAKIN?? SOMETIMES IT SHAKES ALOT....SOMETIMES A LITTLE BIT
EGlove23 is offline
Old 05-20-2009, 01:36 AM
waaBAAH's Avatar
CAPS IS THE NEW COOLEST THING HAVNT U HEARD>
OK DIS IZ WHAT U DO
U FIRST CREATE A VERY GUD TITLE GOOD JOB YO
THEN YOU SPELT VTECH WRONG FOO IT VTEC NOT VTECH GET A CLUE
THEN YOU TYPE IN DA CAP METHOD WHAT WRONG YOUR CAP BUTTON BROKE>
WELCOME TO HONDA TECH YO
waaBAAH is offline
Old 05-20-2009, 03:24 AM
Davus's Avatar
Shaking, check alignment. If we don't know your actual mathematical miles driven per 'gallon' or litres used per 100 kilometers, it could just be the stock fuel gauge being inaccurate as always.
Davus is offline
Old 05-20-2009, 05:52 AM
Former User's Avatar
Start by checking/replacing the spark plugs, plug wires, distributor cap, and rotor.
Former User is offline
Old 05-20-2009, 07:05 AM
EGlove23's Avatar
TALKING ABOUT SPELLING? RIGHT....GUD IS REALLY ((.GOOD.))!! AND I TYPE CAPS OR HOWEVER I FEEL LIKE TYPING ;D
EGlove23 is offline
Old 05-20-2009, 07:32 AM
shawn_crx's Avatar
balance your tires....
check for timing issues and a/f ratio's.
shawn_crx is offline
Old 05-20-2009, 08:30 AM
Jimster480's Avatar
caps only is for fgts. this is your first issue. Do you know if its misfiring? do you know how to do math? fill up tank and drive miles. use the fkn odometer. We cant help you with no information. Shakes and uses fuel, ya ok thats so much info rofl. When did u last do oil change? how much do you drive a day? is the car stock? etc.
Jimster480 is offline
Old 05-20-2009, 08:34 AM
Adankid's Avatar
sell it and get yourself a camry. :D
Adankid is offline
Old 05-20-2009, 09:15 AM
Jimster480's Avatar
camrys are gay.
Old 05-20-2009, 01:50 PM
waaBAAH's Avatar
SELL UR CAR AND USE URE VTECH PHONE TO CALL CAB
waaBAAH is offline
Old 05-20-2009, 02:28 PM
xwhitchx's Avatar
well i had this happen to me, it was idleing at a little over 100rpms, (and i dont mean 1000) it was shaking like hell,(timing was good) and my mpgs sucked ***. so i swapped the engine, the took the old one apart.... it had bad rings, and the head was cracked, but thats what happens when you get a d15b2 for $100, id say it was worth the money cuz it lasted 2 months, 3k mils
xwhitchx is offline
Old 05-20-2009, 02:36 PM
chinkstahh's Avatar
i have a 94 eg and i also had the same problem. i found out my engine was running on two cylinders, and had that fixed right away. mechanics told me my engine timing was off which made me burn extra gas.
chinkstahh is offline
Old 05-20-2009, 02:45 PM
1992hondacivicvx's Avatar
does ur car smell like gas ?
1992hondacivicvx is offline
Old 05-20-2009, 03:55 PM
Jimster480's Avatar
how do people not notice things like bad rings or a cracked head or running on 2 pistons? omfg srsly. Blowing smoke and shaking like **** doesnt make lights go off in ur head?
Old 05-21-2009, 04:00 AM
kojiwafu's Avatar
I had this issue before. just a great thing to put on your carb engine, "enging support" it helps you get no shaking feeling. works 100% also check the timing if its advance or delay, it consumes more gas, its like having a 1.8L engine for a d15 non Vtec engine. :D good luck!
kojiwafu is offline
Old 01-14-2013, 02:11 PM
Ryan96GSR's Avatar
I'm going to say this.
I would start by telling us what maintainence you've done to the car already to help us, help you.
Ryan96GSR is offline
Old 01-14-2013, 02:13 PM
Almost 5 year-old thread closed. The OP has probably moved on.
PhantomX
12-30-2005 11:57 AM
LS_teg07
03-12-2004 04:53 AM
flatline
12-29-2003 11:05 PM
Y2Phunk
10-22-2003 10:43 PM
Quick Reply: car shakes a lot and wastes alot of gas?
