Engine Coolant Temp (ECT) sensor questions
Old 05-11-2012, 05:15 PM
  #26
spoolnpsi's Avatar
Default Re: Engine Coolant Temp (ECT) sensor questions
Thanx
spoolnpsi is offline
Old 05-11-2012, 06:47 PM
  #27
Former User's Avatar
Originally Posted by spoolnpsi
Where is the coolant switch located on a 91 civic dx....It's not on the therm housing.
This question fits in the EF forum, but here's the answer:
It's located to the left of the oil pressure switch on the rear of the block. It has 2 wires - Yel/Grn and Blk.
Former User is offline
Old 05-11-2012, 06:53 PM
  #28
spoolnpsi's Avatar
Thanx bro.
Old 07-14-2012, 12:21 AM
  #29
egb20505's Avatar
i have a question towards the cooling problems. my gauge cluster says my car is running at 210 degrees. like a idiot i figured there would be pressure there for the cap should spray coolant out. i put a towel over it and opened it. there was no pressure and the coolant should have been boiling but it wasnt. is there a reason my gauge could be giving me the wrong reading from the signal sensor
egb20505 is offline
Old 07-14-2012, 01:48 AM
  #30
The temp gauge in the cluster does not give digital read outs. Where does 210F come from?
Old 07-14-2012, 09:36 AM
  #31
egb20505's Avatar
i had a buddy splice a gauge into the signal wire that comes from the signal sensor to the cluster. it says the car is running hot but its not even hot enough to open the t stat. i know the gauge on the cluster is shot. im just lost on what to check now
egb20505 is offline
Old 03-06-2013, 05:39 PM
  #32
crazyhouse2011's Avatar
Can somebody upload a picture of the thermostat housing for a 95 civic ex please? I'm trying to do all of this crap you guys are talking about but I can't seem to find the location... thanks.
crazyhouse2011 is offline
Old 03-14-2013, 06:31 PM
  #33
RyBread68's Avatar
RyBread68 is offline
Old 03-14-2013, 06:33 PM
  #34
RyBread68's Avatar
It's right on the back of the block
Old 07-01-2013, 06:04 AM
  #35
junior91hondaac's Avatar
Originally Posted by hondatango
ok i have followed all this in to a t and replaced all sensor except under the distributor and still gauge works but fan still not kick on should i replace that sensor too? i also replaced relay just incase and jumped the pins to test fan and the fan runs but when car gts hot it not kick on help please lol
how did you fix your fan problem.i have the same issue.
junior91hondaac is offline
Old 07-26-2013, 05:49 PM
  #36
Originally Posted by speedracer9k
unplug the sensor off the t-stat housing and take a paper clip and jump to 2 terminals on the connector. the fans should come on. if they dont the fans dont work. if they come on, then you have another problem. try that and let me know.
what other problem
Old 07-26-2013, 06:04 PM
  #37
Originally Posted by TsunamiR
You should check if there are sensors in the 5 volt control!
what 5volt control box and were is it located? thank you for your time.
Old 07-26-2013, 06:13 PM
  #38
hi ron how are you?i have a problem with my coolinng fans not coming on. the a/c fan does come on after the engine is off at times but not the radiator fan on the drivers side.i check everything to the temperature sensor,burp the system everything ang still the radiator fan dont turn on.you think it might be the timer underneath the steearing wheel?and what does the sensor under neeath the dizzy is for?
Old 03-02-2014, 01:55 PM
  #39
hand's Avatar
See below for how to replace coolant temp sensor on a civic. This forum helped me, wanted to pay it forward.
hand is offline
Old 03-15-2014, 08:48 AM
  #40
what is the 5 volt youre talking about
Old 12-10-2014, 02:30 AM
  #41
Cdeveleigh's Avatar
Did you find out what the problem was I have the same issue. My hot temp light comes on and the fan don't cut in and when I take the top off the rad it don't bubble over any help would be fine. I changed the thermostat, but still no change,, I'm stumped.
Cdeveleigh is offline
Old 12-10-2014, 01:26 PM
  #42
If you have tech questions, please create your own thread.
mon2mon2
01-17-2022 06:49 PM
fleabag
12-19-2011 01:33 PM
arkomandos
11-15-2010 09:15 PM
chattownrexer
07-10-2004 02:45 PM
Quick Reply: Engine Coolant Temp (ECT) sensor questions
