4x114.3 conversion
Re: 4x114.3 conversion
I might not be totally correct, but if the USDM DC2 ITR is the same as the `98 v6 accord, then I would assume you could bolt the accord 4x114 brake setup on the ek.
If you have a choice, I would stay away from the `96 JDM DC2R brakes. I have them on mine and I want to get rid of them. It's basically the same brakes as the GSR, but with a different lug pattern. I have only found one place in the US that sells aftermarket brakes for this useless setup. Everybody has rotors for accords and preludes but not the `96 JDM DC2 ITR spec brakes.
Only reason I have the brakes is because I bought a EK SiR without any brakes on it at all and I needed something to slap on while I'm building the chassis.
Hope I helped.
Hope I helped.
He is not talking about brakes and no you can not use Prelude/Accord hubs.
The only solution besides 96 ITR hubs is
Honda part number
44610-S10-000
from Honda Ev plus. This only works for the front.
You can use Prelude VTEC discs for 96 ITR because they use the same caliper.
Honda part number
44610-S10-000
turboeh6
12-11-2007 06:33 PM
