Grinding noise when clutch is engaged
Old 05-13-2009, 09:57 AM
  #26
Former User's Avatar
Default Re: Grinding noise when clutch is engaged
Originally Posted by bernabeguzman
yea it is your release bearing...
Did you mean input shaft bearing?
Former User is offline
Old 05-14-2009, 07:28 AM
  #27
black96's Avatar
yea it is your release bearing for shour you have to take the tranny out and change it, its pretty easy but takes time
im a bit confused too, did you mean isb or t/o bearing?
black96 is offline
Old 05-23-2015, 04:36 PM
  #28
scottyd423's Avatar
I have a similar problem...my car was fine when I parked it this morning, no noises at all I got in it just started it up and when I went to pull out i pressed the clutch to shift into first and the clutch made a terribly loud grinding noise and the ebrake light came on at the same time as well, I figured its the TOB but why would the brake light on my dash light up??
scottyd423 is offline
Old 01-03-2016, 08:15 PM
  #29
Olopez8711's Avatar
My 99 civic ex makes this like grinding noises in 1 and 2 gear! But not wen is parked or in neutral! Only wen I'm on drive! But if I hold the clutch it goes away! And setimes wen I take off make this weird noise! If I let go off the gas n then go again it come off! Help?
Olopez8711 is offline
Old 01-03-2016, 08:34 PM
  #30
Create your own thread rather than bump an old one.
Nick Kozeski
09-02-2015 02:18 PM
AlaskaREX
05-30-2013 06:53 PM
shermanyang
12-01-2012 11:24 AM
HondaMan_TypeR
14
01-06-2009 05:21 PM
tsdenny
08-09-2006 05:47 AM
Quick Reply: Grinding noise when clutch is engaged
