Old 05-10-2009, 02:02 PM   #1
jdmboy94
Default Car Sputter and Backfires? help??
when im driving down the road the car if fine, then when you go to accelerate harder than normal everyday driving from a stop or while driving, the car shutters and backfires then when you let off the gas it goes back to normal. it runs perfect other than that. any help? thanks its a h22a in a del sol.
94 Integra ls- jdm gsr swap turbo- sold
95 Del-Sol- Traded
94 Integra ls-Built,waiting on dyno numbers
jdmboy94 is offline   Reply With Quote
Old 05-10-2009, 02:16 PM   #2
TravisCadello
1992 Honda Civic
TravisCadello's Avatar
Default Re: Car Sputter and Backfires? help??
ECU problem maybe any CEL's? check the TPS sensor.
TravisCadello is offline   Reply With Quote
Old 05-10-2009, 03:41 PM   #3
jdmboy94
no there are no Cels. ill check it but its driving me nuts, it runs perfect till you give it more gas. then it starts and you let off and it stops? i dont know what else it could be?
95 Del-Sol- Traded
Old 05-10-2009, 03:45 PM   #4
civic_driver
civic_driver's Avatar
Have you checked the timing, both mechanical and ignition?
For Sale Thread
civic_driver is offline   Reply With Quote
Old 05-10-2009, 04:58 PM   #5
jdmboy94
yea i checked the timing and it was good?? it ran fine the other day. it just started doing it?
95 Del-Sol- Traded
Old 05-10-2009, 05:56 PM   #6
civic_driver
Probably something wrong with the dizzy.
For Sale Thread
Old 05-10-2009, 06:14 PM   #7
TravisCadello
1992 Honda Civic
yea,^^^
Old 05-10-2009, 06:15 PM   #8
TravisCadello
1992 Honda Civic
or clogged fuel injectors or fuel filter.
Old 05-10-2009, 08:14 PM   #9
jdmboy94
i just put some injector cleaner in it yesterday and changed the fuel filter as well. then tonite i went to leave my girlfriends house and it wouldnt start. it just turned over but nothing. no CELs, fuel pump is priming, just put injector cleaner in it, fuel filter, replaced the ignition coil, it has the msd on it, spark plug wires.
95 Del-Sol- Traded
Old 05-11-2009, 04:23 PM   #10
jdmboy94
bump?
95 Del-Sol- Traded
Old 05-11-2009, 06:36 PM   #11
hheard15
check and clean the VTEC solenoid.....it sounds like theres a possibility you fryed your ECU also...that happened to me....its almost like its bogging out...try a different ECU preferably a stock one
hheard15 is offline   Reply With Quote
Old 05-13-2009, 05:03 AM   #12
los12
los12's Avatar
bumpp because my car is doing the same thing
H2B EF
MAXXDOUT FOR LIFE
los12 is offline   Reply With Quote
Old 05-13-2009, 07:02 AM   #13
PphamEK
PphamEK's Avatar
Pphamek Pphameg
Send a message via AIM to PphamEK
check the fuel pressure. my buddy had a h22 eg and that was the problem
PphamEK is offline   Reply With Quote
Old 05-13-2009, 06:52 PM   #14
YangFlavor
YangFlavor's Avatar
same thing happen 2 me too
YangFlavor is offline   Reply With Quote
Old 05-13-2009, 07:06 PM   #15
jdmboy94
ok well today i bought new msd spark wires. and i have the blaster 2 coil on the car. and the wire going from the coil to the dizzy was messed up and i found it out the hard way lol, i went to grab the wire and it shock the s**t out of me, i replaced all the wires. and it helped out alot but it still backfires and sputter a little bit at high rpms? i put some fuel system cleaner in it and injector cleaner, so hopefully that will clear the rest of it up.
95 Del-Sol- Traded
99, backfire, backfired, backfiring, car, civic, clogged, driving, filter, fuel, honda, integra, ls, sputtering, turbo
