Pressure sensor on condensor
Does anyone know if you can replace the pressure sensor on the condensor without loosing the FREON?
Thanks
Thanks
Re: Pressure sensor on condensor
Well since no one here knows anything about the pressure switch I will now tell you from my lesson learned.
The pressure switch on the condensor is the high pressure switch and prior to removel the system must be drained of freon. The switch on the low pressure side does have a valve that closes upon removal so it can be removed without loosing freon.
Hope this might help soneone else
Delslowman87
04-27-2020 03:08 PM
