Go Back   Honda-Tech > Honda and Acura Technical Forums > Tech/Misc
Old 05-06-2009, 11:01 PM   #1
itslogz
itslogz's Avatar
Send a message via AIM to itslogz
Default Brand new duralast axles, pieces of crap? Vibration when accelerating
Just did the following things to my car over the past week, all at once but had to work weird hours so it took me a week to complete it all, just got it back together and drove today.
New OEM front lower ball joints
New Duralast outer tie rods
New (Not remans) duralast pass and driver side axles
ES hyperflex full bushings in the front, LCA, Shockfork, radius bar's, sway bars, endlinks, etc..
New reman cardone brake calipers in the front
Got all that back together, and the only problem from what I can tell is vibration under certain acceleration periods. Mostly between 2500-4000 RPMs then it seems to slack off.
So basically what im asking is, who here has bought brand new duralast axles before from autozone and they came straight out the box being piles of crap. I know they're cheap and i shouldnt expect much, but i'd atleast expect me to be able to use them haha. Im taking them back out as soon as i get more ball joint boots because I know im gonna trash the old ones trying to get the balljoint back out of the LCA.
TIA.
Originally Posted by 2LEM1 View Post
I would drown puppies for 6 figures
itslogz is offline   Reply With Quote
Old 05-07-2009, 09:04 AM   #2
deathplaza
deathplaza's Avatar
Send a message via AIM to deathplaza
Default Re: Brand new duralast axles, pieces of crap? Vibration when accelerating
totally not unheard of for parts stores to sell u axles that only last a day or something. happened to my friend just a week or so ago, they will give you another set if u complain but u have to make sure your car is straight first cuz what your explaining to me doesn't really ring axles. axles ussually make a clicking sound that increases with speed and is always present, or they break off the cv joint.
deathplaza is offline   Reply With Quote
Old 05-07-2009, 09:37 AM   #3
sierrahiker8
sierrahiker8's Avatar
Take them back, they have a lifetime warranty. Plus they are made by Cardone, who makes almost all aftermarket part store axles.
sierrahiker8 is offline   Reply With Quote
Old 05-07-2009, 10:00 AM   #4
foxfai
foxfai's Avatar
Check this thread, you might need to get a different one to replace it.
http://www.honda-tech.com/showthread...axle+vibration
1994 Acura Integra LS
Everything is rusted and broken..... *sigh*
foxfai is offline   Reply With Quote
Old 05-07-2009, 06:08 PM   #5
Colin
Colin's Avatar
iTrader Rating: (1)
Send a message via AIM to Colin
I've been using raxles for almost 10yrs now, and I did get one bad axle from them as a replacement. It was supposed to be new and good but it vibrated. There's just going to be a certain chance you get a bad part - if it happend w/ Raxles (who I still recommend at every chance I get) then it could easily happen to the cheaper less reliable autoparts store ones.
Colin is offline   Reply With Quote
Old 05-07-2009, 09:09 PM   #6
itslogz
itslogz's Avatar
Hmm
Well im going to take them both back and replace them with the ones they give me and hope they dont do the same ****, if they do ill try to get a refund and try some more bullshit axles i guess. and if that dont work, then ill get some raxles. Im trying to save $ if possible because im fixing to have my car painted so thats why i went cheap on this one.
Old 05-22-2009, 11:47 PM   #7
itslogz
itslogz's Avatar
Alright updating this thread for people who search for the same problem to see the outcome.
Took my driver side autozone axle out, replaced it with a reman. Napa axle, and the vibration issues are gone. Im gonna replace the pass. side tomorrow with the other napa I got, just got the driver side done tonight, then ima take the duralast's back for my $120 refund that I damn well deserve after switching out axles twice because of it lol Napa's were $47 a piece for reman's with no issues and I payed $59 a piece for the autozone axles with mad issues.
Go to napa for axles, not autozone. Or better yet, go to raxles or driveshaft shop, but if you need cheap replacements for a simple DD or something, dont use autozone, plenty of others to agree with me on this one as well im sure.
Update: Installed passenger side napa axle tonight, so both napa reman's are in and 100% of the vibration is gone. Napa > Autozone for this specific part and the napa's were $30 cheaper than what i payed for the new autozone ones.
Old 05-24-2009, 07:51 AM   #8
jlude90
jlude90's Avatar
Send a message via AIM to jlude90
my NAPA axles were pieces of ****, wouldn't seat, had to replace them and after only a few months of wear i had to replace them again
now i'm beating the living **** out of Raxles and like Colin said, they're fantastic and i as well recommend them every chance i get, definately worth it if you get fed up with the parts store stuff
jlude90 is offline   Reply With Quote
Old 08-05-2009, 09:07 AM   #9
A.C. Slater
A.C. Slater's Avatar
Jgtc15
I'm gonna bump this thread backup...
when I first put my swap in it had stock axles, after a burnout or 2 they started clicking...(NO VIBRATIONS though)...
Sooo since my friend had warranty on a set of AUTOZONE axles, we figured wed get nice new ones yay.
We did...and they came out vibrating...over time it got worse and a couple of days ago we went and got another set and also got nice new syncromesh...
well what do you know
STILL VIBRATINGG FUUUUUUUUUUUUUUUUu
These now seem to vibrate at lower end of the powerband while my old ones vibrated more on top...
It ****ing sucks, EVERYTHING VIBRATES, I can feel my mirrors vibrating change in the coin pocket, **** in the glove box.
Autozone axles ****ing suck **** you autozone.
Atleast i didnt spend a dime on these axles...just time and effort switching them out hoping for a non vibrating set.
Is there any way a CV axle shop can fix them/balance them? There's a CV axle shop only about 5 miles from my house...
Now I have an EK with a B series, but the axles were from a 95 GSR with ABS...would this matter at all? I don't think the axle length is different but could it have something to do?
Albert Squad FTW!
Spoon lip scrapin, spoon n1 screamin, spoon mirrors reflectin, spoon sw388's rollin, spoon wing downforcin spoon stickers stickin
A.C. Slater is offline   Reply With Quote
autozone, axle, brand, calipers, cardone, crap, duralast, front, good, honda, makes, raxles, reman, ujoints, vibration
