ABS codes for 96 honda accord.
Old 05-03-2009, 11:43 AM
Fc_v8's Avatar
Default ABS codes for 96 honda accord.
Well im searching for about 1hr now and cant find any codes for ABS 96 accord? Any one want to be helpful and find me a working link?
im pulling 3 quick flashes and then 1 quick flash? any ideas?? Help appreciated.
Old 05-03-2009, 11:56 AM
dtapia's Avatar
Default Re: ABS codes for 96 honda accord.
code 1 is for pump over run and if it's 1-3 then a high pressure leak. most common is the abs accumulator or modulator. look for leaks at the pump area.
Old 05-03-2009, 04:32 PM
Fc_v8's Avatar
So i need a new abs unit? i guess no one has the link to all the codes.?
Old 05-03-2009, 05:41 PM
dtapia's Avatar
did you look for any leaks ? if it's leaking then yes a replacement will be needed and also replace the accumulator as a unit.
what other abs codes do you have that i did not answer for you ?
Old 05-03-2009, 06:15 PM
Fc_v8's Avatar
well like i said its 3 quick flashes then 1 quick flash. i dont get what you mean buy 1-3?? its not 1 quick one then follow by 3 quick ones. and i did not look for leaks yet because my brother just left back home and i was trying to figure out the codes for him before he leaves but i might just have to fix/help him next time he comes down. Thanks alot dtapia for your Help!!
dcarey
12-11-2012 12:18 PM
honda_kid42
08-15-2010 12:17 PM
2000FBPITR
09-19-2009 01:03 PM
regiment1
03-23-2004 11:15 AM
Quick Reply: ABS codes for 96 honda accord.
