| Welcome to Honda-Tech! | ||
#1 |
Ok, while driving the car the engine code pop on and it says B12 and the little wrench light is on, my engine oil % is at 15 right now, could that be the problem? When i change the oil do i need to take it to a dealer to have the codes taken away? Or can i reset it by moving the battery terminals and leaving them off for a min. Any help will well appreciated.
#2 |
b12 i think is oil change, tire rotation
#3 |
if u hold down the odometer button while its on the oil life screen it resets it... as far is a the wrench and then codes thats just ur maintenance minder... anything being wrong would pop the check engine light.. so ur good.. just get ur normal maintenance done and reset it...
#4 | |
Ok so how would i go about removing the the wrench light after i have done the oil change and tire rotation? |
#5 |
Got it reseted by pushing and turning the od switch. Thanks guys.
| Tags |
| 06, 12, 2006, 2008, accord, b12, check, civic, code, codes, engine, honda, maintenance, minder, odyssey, service |
