Go Back   Honda-Tech > Honda and Acura Model-Specific Technical Forums > Honda Civic (2006 - Current)
Old 04-27-2009, 11:59 AM   #1
B0tta
Icon6 08 Civic EX oil capacity
I just changed the oil on my 08 Civic EX. 1.8 L engine. Drained the oil changed the filter. Refilled the crankcase with 4 Quarts of oil. Now when I check the oil with the dipstick it reads low just barely registering on the stick. Car is level, oil has had 1 hour to drain back into pan. New oil is clean, but I can read it. Could I have the wrong dipstick? Both my owners book and the service manual say 3.9 Quarts with filter.
B0tta is offline   Reply With Quote
Old 04-27-2009, 04:08 PM   #2
pd0019
pd0019's Avatar
Default Re: 08 Civic EX oil capacity
ive noticed that it is very hard to read the dipstick on the r18. try looking very close...it sounds like you did everything correctly
genesis automotive - injen - jlb motorsports - frank's fab shop - options auto
current: '00 ap1 & '98 ej8 ---- '07 fg1 = totaled ---- '94 accord = sold
pd0019 is offline   Reply With Quote
Old 04-27-2009, 05:10 PM   #3
ekb16
ekb16's Avatar
iTrader Rating: (1)
Send a message via AIM to ekb16
i think u should be good.. 4qts is how much i usually put at work
B.A.R. member as of 3/18/09 JDM gsr in 98 hatch
Voches: chickwithastick,93allmotorcoupe,jomama,punoy69,Tom theman70
ekb16 is offline   Reply With Quote
Old 04-28-2009, 03:29 AM   #4
MWLW20
MWLW20's Avatar
is the car on a level surface?
96 EK Coupe - DD
08 FG1 - SOLD
My Build Thread http://www.honda-tech.com/showthread.php?t=2629367
MWLW20 is offline   Reply With Quote
Old 04-28-2009, 10:48 AM   #5
Zeusone
Zeusone's Avatar
can you read?
Zeusone is offline   Reply With Quote
Old 04-28-2009, 10:52 AM   #6
MWLW20
MWLW20's Avatar
Originally Posted by Zeusone View Post
can you read?
yes, I can read...I just looked over it quickly and missed that part.
96 EK Coupe - DD
08 FG1 - SOLD
Old 05-02-2009, 12:58 PM   #7
IN VTEC
2012 Lexus CT
My Garage
IN VTEC's Avatar
iTrader Rating: (2)
Ben Chang Dr Eugh
Send a message via AIM to IN VTEC
The R18's take 4.2 to 4.3 qt's to put it at the top line.
IN VTEC is offline   Reply With Quote
Old 05-02-2009, 02:03 PM   #8
av911
av911's Avatar
av911 is offline   Reply With Quote
Old 05-02-2009, 02:14 PM   #9
IN VTEC
2012 Lexus CT
My Garage
IN VTEC's Avatar
iTrader Rating: (2)
Ben Chang Dr Eugh
Trust me, I work at a dealership and typically do 2 to 3 of these a day.
Unless you want to challenge the metering on our pumps, but I can do two things to clear that up. One, I can do a comparison against a calibrated standard. Then, I can run a series of samplings with that calibrated standard to describe the historical and predicted volumes that this pump will issue under the ambient conditions during this time of year for my location. I probably won't do that because I really don't care that much and I'm lazy as **** right now.
Old 05-02-2009, 02:45 PM   #10
av911
av911's Avatar
It ALWAYS takes 3.9-4.0 qts for me, every single time, I don't know what you're doing.
Old 05-02-2009, 05:40 PM   #11
pd0019
pd0019's Avatar
its 3.9...i dont know where you're getting your numbers from but you are wrong IN VTEC
Old 05-02-2009, 05:46 PM   #12
K5^
Brand New
2008 Honda Civic
K5^'s Avatar
Rasscasse
Since when did working at a dealership mean ****? Moreover, more often than not, dealership personnel have f ucked up something on my car which is why I gave up on them all together. So if you do work for a dealership, I wouldn't go on bragging about it because it doesn't carry much weight with people.
SpunkyFresh | I OEM | FA*Squad #1
K5^ is offline   Reply With Quote
Old 05-21-2009, 11:53 AM   #13
B0tta
Thanks for the info. You are the only one who knows what he is doing. I also found a person at the Honda parts counter who owns the same car as me. He also verified the capacity at 4.4 quarts
Old 05-21-2009, 01:27 PM   #14
av911
av911's Avatar
I guess following the owner's manual, service manual, and the fact I put 3.9-4 qts, which sits right at the top line of the dipstick is wrong....
Old 05-21-2009, 01:29 PM   #15
K5^
Brand New
2008 Honda Civic
K5^'s Avatar
Rasscasse
Obviously a tech at a Honda dealership is much more in the know than the engineers that designed every aspect of these cars. The owner's manual is clearly second protocol after the omnipotent techs.
Old 05-26-2009, 04:18 PM   #16
safedriver
iTrader Rating: (1)
I have a 08 SI.
I ended up putting 4.4 qts.
I have a 06 EX and I fill them till their dip stick indicates full.
Last edited by safedriver; 05-27-2009 at 05:22 PM. Reason: SI info decribed for EX sedan.
safedriver is offline   Reply With Quote
Old 05-26-2009, 07:25 PM   #17
Nighthawk R18
Nighthawk R18's Avatar
Send a message via AIM to Nighthawk R18
change oil, put 3.9, drive it, and stfu
if anything f's up i have the owners manual to back me up instead of the dipstick.
jt3f.
Nighthawk R18 is offline   Reply With Quote
Old 05-26-2009, 08:42 PM   #18
K5^
Brand New
2008 Honda Civic
K5^'s Avatar
Rasscasse
Think with your dipstick Jimmy!
Old 05-27-2009, 10:19 AM   #19
pd0019
pd0019's Avatar
4.2-4.3 qts is what you put in an SI not an EX
08, 2006, 2007, 2008, 2009, 96, acura, capacities, capacity, civic, engine, honda, oil, quarts, tl, vtec
