| Welcome to Honda-Tech! | ||
#1 |
1992 Honda Civic |
ok pulled the wrong fuse in my accord! need the code to get it to work were is the code located at?
#2 |
I dont know what yr accord you have but some dealers put the serial sticker hidden around and on the glove box. some head unit can give you its serial number buy holding the 1 and 6 key, then push the on button/****. if none of that works, then you have to removed the unit and look on the label for the serial. Last you go to the dealership to prove you are the owner of the vehicle and then can try find the code for you. If it is the back up fuse that you pulled, from under the engine, please remember to perform the idle learn procedure.
#3 |
You can call the dealer with the vin of the car the stereo came from and they will give you the code for it. Some times they want you to go in though.
Honda, making pizza delivery profitable since 1977. |
#4 |
1991 Honda CRX |
https://radio-navicode.honda.com/
this worked for my 00 accord, but i had to use the info from the guy i bought it off of, who i think was the original owner
2000 Accord coupe 5 speed -sold 91 CRX DX 5spd just hit 300k miles! |
| Tags |
| 01, 2000, 2003, 2008, accord, acura, code, head, honda, odyssey, radio, reset, resetting, tsx, unit |
