no power to gauges, car wont start, what fuse is it?
Old 04-24-2009, 03:34 PM
oneprelude's Avatar
Default no power to gauges, car wont start, what fuse is it?
I believe a fuse has gone out, i have no power to my gauges and my car wont start. Battery is good. Any suggestions? Thanks
Old 04-24-2009, 06:19 PM
green99civic's Avatar
Default Re: no power to gauges, car wont start, what fuse is it?
I would look at you maxi fuse if nothing is working. Make sure the connection to your battery is good at negative and positive. Would check dash fuses using a test light underneath the dash also.
Old 04-24-2009, 07:25 PM
Former User's Avatar
What electrical components do have power? Does the starter crank the engine but it won't start? Or does does the starter fail to crank the engine?
Old 04-25-2009, 04:02 PM
oneprelude's Avatar
headlights work fine, car wont even crank at all. When i turn the key to the on position, my gauges wont light up. I have no power to even start
Old 04-25-2009, 04:12 PM
Check the ignition switch.
Old 04-25-2009, 07:11 PM
hatchnideas's Avatar
check all the grounds... front of engine, tranny ground, thermostat housing ground...
Old 04-26-2009, 08:49 AM
oneprelude's Avatar
my car was working fine up to this point. My car was stolen, the ignition coil was hanging under the steering wheel, i tried to put it back in place. After doing that, there was no power whatsoever. So there must be a short somewhere
TIRENECK
03-02-2019 11:16 AM
Jokester
04-13-2010 01:13 PM
kin413
06-15-2007 10:23 AM
sabot808
04-21-2007 09:37 PM
strils
01-11-2007 08:06 PM
Quick Reply: no power to gauges, car wont start, what fuse is it?
