lug stud replacement?
Old 04-24-2009, 02:11 PM
spens 91 Ef's Avatar
Default lug stud replacement?
ok i have 1 bad lug stud on my car its all rusted and the threads are mest up so i only have 3 lugnuts on my driver side i was wondering how to take my lugs studs out can i just take off the caliper and not have to drain the brake fluid, also will any kind of honda studs work for my car 91 honda civic hatchback
Old 04-24-2009, 02:45 PM
Keyboard Humorist
4drEF's Avatar
Default Re: lug stud replacement?
Sine the stud has not actually broken, you are going to have to remove the entire knuckle. you can unbolt the caliper and use a coat hanger or something to hold it off to the side. You don't want to just let it hand down pulling on the fluild line.
You will need to have the hub pressed out to replace the stud so you might want to replace the wheel bearing while you are at it.
Old 04-24-2009, 02:54 PM
ya its not broken but its shorten and not threadable
Old 04-24-2009, 03:00 PM
Keyboard Humorist
4drEF's Avatar
What do you mean it's shortened?
I'm asking because it's a common problem that the stud break off when they are overtightened frequently. They all seem to break at the same place too. There is a write-up someplace (I'm having problems finding it) that shows how to replace the stud if it has broken off like I am explaining - without removing the knuckle and pressing the hub off! I guess you could break the stud yourself with a grinder or saw... it's hard steel though so good luck.
Old 04-24-2009, 03:12 PM
nico91civic's Avatar
this will show you how to get to the hub
http://www.performanceforum.com/wesv...b/rearhub.html
its for the rear but its the same idea
when you have the hub exposed and the caliper removed from the bracket rotate th hub so that the broken nut is in line with where the caliper would be, theres an opening in the guard that cover the back side of the rotor there, then gently tap it out of there, it will be slow but you dont want to beat on the hub assymbaly while its in the wheel bearing, once the broken one is out put the new one in from the back side and hammer it back in, once again gently, you could also just tighten the lug nut to pull it but youd need a bunch of washers to take up the space
Old 04-24-2009, 03:14 PM
like it doesnt look like its been broke off its just shorter then the rest and not threadable, do you know if i could use any kind of honda lug to replace it
Old 04-24-2009, 07:38 PM
id say thats a safe bet since they all have the same thread type for the most part, you could just get a set of ARP ones there like $11 for 4 i think and you wont wreck them in the future
Old 04-24-2009, 10:07 PM
mitsubishiv5's Avatar
i learned something today :D
d16skivic
09-25-2008 07:04 AM
prelude_93vtec
05-08-2008 08:22 PM
Brownjd
10-15-2004 07:20 AM
Mike_C
06-10-2004 09:25 PM
magic hat #9
08-07-2002 07:30 PM
Quick Reply: lug stud replacement?
