> Honda Civic (2006 - Current)
Old 04-18-2009, 03:35 PM   #1
Gator0302
2007 Honda Civic
Default Velocity Stack question
I have a K&N cai and so the air filter is still inside the engine compartment. Would it be better to use the velocity stack with the filter or with the air hose at the front of the bumper? I live in Socal so I don't have to worry about much rain or wetness.
Gator0302 is offline   Reply With Quote
Old 04-18-2009, 07:55 PM   #2
i-VTEC_DOHC
i-VTEC_DOHC's Avatar
Default Re: Velocity Stack question
i honestly dont know if those velocity stacks even make a difference
FG SQUAD #1 / NOTHING ON MY CAR IS FOR SALE UNTIL MAY 16TH!!!!!
i-VTEC_DOHC is offline   Reply With Quote
Old 04-18-2009, 07:56 PM   #3
vladd
2000 Acura Integra
My Garage
what's a velocity stack? a bumper inlet for the cai?
vladd is offline   Reply With Quote
Old 04-18-2009, 07:58 PM   #4
i-VTEC_DOHC
its a little conical thing that supposedly increases the velocity of the air entering the filter. check it out bro
http://passwordjdm.com/Blox-Racing-V...k-P2488C0.aspx
Old 04-19-2009, 10:33 AM   #5
2008fijibluesi
2008fijibluesi's Avatar
I talked to a kid at the track on Friday who has a K swap in his '94 Civic sedan. He said his velocity stack added 6 hp on the dyno. I don't know if that's true but he's never BS'd me before.
FG SQUAD #2
2008fijibluesi is offline   Reply With Quote
Old 04-19-2009, 10:46 AM   #6
Kiwibird83
Kiwibird83's Avatar
Velocity stacks are really only effective on race built motors, usually consisting of ITB's or most noticeably on carburetor cars and motorcycles with 1 carb per cylinder. On a motor like the K20 your better off just buying an aftermarket intake and saving yourself the money.
Originally Posted by xtrac1 View Post
How about you shut the **** about my opinions?
Originally Posted by k3nnex View Post
I made out with a fat girl that smelled like raid
Kiwibird83 is offline   Reply With Quote
Old 04-19-2009, 11:23 AM   #7
mormonboy
mormonboy's Avatar
if any of you understood how a velocity stack worked, you'd understand that it makes significantly more HP than a regular cotton/paper filter.
i run a Original Brian Peterson Innovation Velocity stack (Blox copied his design).
mormonboy is offline   Reply With Quote
Old 04-19-2009, 12:14 PM   #8
Kiwibird83
Kiwibird83's Avatar
Yes, if only we all knew as much as you do....
What does a velocity stack have to do with paper element filters? A velocity stack is not a filtering medium. Are you running a straight Velocity stack on your throttle body without a filter or something?
Velocity stacks on log manifold with runners is snake oil, they are designed for Throttle bodies and Carburetors to help high volume airflow characteristics at high RPM, and in Carbed applications also helps keep fuel going down the neck of the carburetor.
Instead of delving into an overbloated rant about physics, let us simply use logic at this moment.
If installing a $3 plastic cone into an intake system or on to a throttle body was enough to net the K20 engine nearly 6 more HP, why wouldn't Honda simply install them from the factory, being that in "Theory" <I.E Bullsh*t> a velocity stack does not effect emissions their is literally no reason for Honda not install this little "Miracle" item to the engine during its assembly.
Any "gains" seen from a velocity stack on a Civic can be attributed to either hacking up the pre-existing air box and piping to add new plumbing, adding an aftermarket air filter, or simply both, in the case of something like an Injen CAI.
Old 04-19-2009, 12:55 PM   #9
vladd
2000 Acura Integra
My Garage
where exactly would it go?
Old 04-19-2009, 01:09 PM   #10
ajgrosch716
2001 Honda Civic
ajgrosch716's Avatar
Send a message via AIM to ajgrosch716
http://en.wikipedia.org/wiki/Velocity_stack
Most of the information here seems correct. The Velocity Stack smooths the air flowing into the engine, which makes it easier to ignite. You attach it to your intake, then purchase a filter that fits on the outside of the large end of the Velocity Stack. I have seen the Velocity Stack work well. Of course it works best with a built engine and tuning.
ajgrosch716 is offline   Reply With Quote
Old 04-19-2009, 09:12 PM   #11
Gator0302
2007 Honda Civic
So, is it more advisable to use it with the air filter or the hose that goes to the front of the bumper?
Old 04-19-2009, 09:33 PM   #12
i-VTEC_DOHC
x2. i saw a drag honda at the last eibach and it had a long *** intake that went through the front headlight and had a velocity stack on it. no filter of course. here it is
Old 04-19-2009, 09:33 PM   #13
i-VTEC_DOHC
look up at the pic i posted. thats where it goes.
Old 04-19-2009, 11:33 PM   #14
Gator0302
2007 Honda Civic
Ive seen a pic like that, but my set up is different. My K&N cai uses the air hose that goes to the front bumper. So there is filter and piping to the throttle body and an air collecting hose that comes from the bumper and connects into the air filter housing. So anyone know would it be better to use the stack at the filter or at the air hose at the front bumper.
Old 04-20-2009, 09:20 AM   #15
miketat594
miketat594's Avatar
Send a message via Yahoo to miketat594
The older K's or a K swapped car that ran off speed density will benefit from a velosity stack.. The z3 motor is a maf density design and will not benefit from the increased airflow nearly as much, you may get slightly lower air temps but the MAF sensor will still control the air/fuel to a factory setting , unless tuned for a velosity stack..
If just looking for cooler air temps , then relocate the battery and flip the intake to the front, where the bat is located.
mike
miketat594 is offline   Reply With Quote
Old 04-20-2009, 10:18 AM   #16
GUILOTINE
Kill Gil
1997 Acura Integra
GUILOTINE's Avatar
http://www.facebook.com/profile.php?id=537873220#!/profile.php?id=537873220
Send a message via AIM to GUILOTINE
At the end of your tubular aftermarket Intake. They are good for about 5-10hp on most street engines depending on the length of the intake piping.
Here's a few pics of my custom ones installed
If anyone is interested in them I have a couple anodized bronze stacks left for $45 shipped including Paypal fees. They are compatible with K&N Filter part# RF-1048
GUILOTINE is offline   Reply With Quote
Old 04-20-2009, 10:32 AM   #17
i-VTEC_DOHC
imagine you suck up a bug or somethin
i dont want to run one in my area because its the desert and its obviously windy and dusty
BOOM!! haaaaaaa
Old 04-20-2009, 10:36 AM   #18
GUILOTINE
Kill Gil
1997 Acura Integra
GUILOTINE's Avatar
BOOM!! haaaaaaa
Just put a filter over it
Old 04-20-2009, 10:39 AM   #19
i-VTEC_DOHC
hmm you obviously dont know how dusty it gets. it gets to the point where chp has to slow traffic to 25 mph on the freeway and guide people through.
Old 04-20-2009, 10:53 AM   #20
GUILOTINE
Kill Gil
1997 Acura Integra
GUILOTINE's Avatar
Should filter as good or better than your existing aftermarket airfilter.
This is what it looks like when installed on a V-Stack
Old 04-20-2009, 11:03 AM   #21
i-VTEC_DOHC
hmm idk if i really want to put that on my injen. it states not to use any other filter. but im not interested in the v stack. all i did was post a pic up of one. and maf cars dont really benefit from a velocity stack as much as the speed density ones do
Old 04-20-2009, 01:13 PM   #22
ChargedSI
2006 Honda Civic
ChargedSI's Avatar
Spoken for truth. Your not going to see much benefit because of the MAF sensor. In the right applications, Velosity stacks work well. I ran a monster velosity stacks on my 65 Chevy Truck that ran a 427 rat motor (duel Holley 850 BP). I also run a velosity stack (open intake system) on my BMW, which gained me around 10whp.
ChargedSI is offline   Reply With Quote
95, civic, fg2, filter, honda, hondatech, install, installing, intake, itr, kn, stack, stacks, velocity, work
