> Lighting
Old 04-07-2009, 10:53 AM   #1
superchargedY8
superchargedY8's Avatar
Send a message via AIM to superchargedY8
Default Fog Light Wiring Help. OEM Switch to Aftermarket
I have a 96 honda civic with an aftermarket fog light kit.
My fog light switch recenly went out so i purchased an OEM switch and apparently the OEM switch is quite different from the aftermarket harness. I have read that in order to connect the OEM switch with the after market harness i just need to match up the 2 ground wires, relay wire, and parking light wire. I am almost positive i know which are which on the OEM switch but I have NO IDEA which are which on the aftermarket harness
someone PLEASE help!!
This is the aftermarket harness:
(I need to know which wire is which)
This is the OEM switch.
(I am almost positive i know which is which on this one)
superchargedY8 is offline   Reply With Quote
Old 04-08-2009, 05:44 PM   #2
ControlNode
1984 Honda Civic
My Garage
Send a message via ICQ to ControlNode
Default Re: Fog Light Wiring Help. OEM Switch to Aftermarket
If you already have the OEM fog light plugs behind the bumper, why not just wire the the after market lights to the OEM harness. If your worried about the load, just put a relay where the OEM fog would hook up and use the relay to control the aftermarket lights. Then they lights will work as they should, only only when Low beams are.
ControlNode is offline   Reply With Quote
Old 04-13-2009, 08:02 PM   #3
hazard2o9
hazard2o9's Avatar
i dont know if this is going to help but you can try
http://www.honda-tech.com/showthread.php?t=2246130
Ej8 Squad Member #428
replica ctr headlights sold
hazard2o9 is offline   Reply With Quote
Old 04-21-2009, 10:15 AM   #4
thomas_garcia08
thomas_garcia08's Avatar
Send a message via AIM to thomas_garcia08
i have the jdm foglight switch. it has four wires out of the back.
2- red with black stripe
2- solid black
i am not using the stock harness for the fog lights.
i bought the aftermarket foglight harness.
thomas_garcia08 is offline   Reply With Quote
2000, accord, aftermarket, civic, fog, harness, honda, how, jdm, light, lights, oem, rsx, switch, wire, wiring
