Clutch not engaging... Need Help
So i dont know what else to do. I have replaced the slave and master cylinder, properly bleed the lines so there is no air in the system, and I still cant go into any gear. The only gear that it will remotely let me get into is reverse and it grinds. By the way, its a b18c1. Let me know what you guys think.
Re: Clutch not engaging... Need Help
The line was bled properly. i re-adjusted the clutch pedal after installing the new master cylinder. I'm not sure about the shift fork though. I am going to pull the transmission tomorrow and check it out but if the pressure plate or flywheel is not loose and the shift fork is not bent then I am going to be stumped.
Check Master cyl, Get air out of the lines, check fork and make sure all bolts are tight. Check shift link and bolts. Was everything ok before ?
jdm_phunk
02-27-2011 05:17 PM
