Go Back   Honda-Tech > Honda and Acura Technical Forums > Suspension & Brakes
Old 03-29-2009, 06:48 AM   #1
corkss
corkss's Avatar
Default How do I lower just the rear of my 99 civic
So I put some new shocks, upper balljoints, and stock eg springs on my 99 civic. The ride is nice!! Going over railraod tracks now are a dream!
The rear end sits a tad high for my likings, how can I lower it a bit? I want the car to sit level, like the SI. Will rear si springs work? What set up would allow it come down a bit?
I don't want to lower the whole car, I've been there, done that.
Thanks in advance!
03' Accord ex
I ♥ HONDA
corkss is offline   Reply With Quote
Old 03-29-2009, 07:15 AM   #2
corkss
corkss's Avatar
Default Re: How do I lower just the rear of my 99 civic
Anybody play with ITR springs on ek civs?
03' Accord ex
I ♥ HONDA
Old 03-29-2009, 08:44 AM   #3
corkss
corkss's Avatar
Ctr suspension?
03' Accord ex
I ♥ HONDA
Old 03-29-2009, 08:50 AM   #4
DOHCIVIC
DOHCIVIC's Avatar
Send a message via AIM to DOHCIVIC
I would just buy a set of Tein lowering springs and lower the whole thing
1977 Honda Civic CVCC(mint)
1977 Honda Civic 1200(chopped and sectioned for trailer project)
2005 Toyota Tacoma TRD prerunner
DOHCIVIC is offline   Reply With Quote
Old 03-29-2009, 10:12 AM   #5
corkss
corkss's Avatar
03' Accord ex
I ♥ HONDA
Old 03-29-2009, 01:03 PM   #6
DOHCIVIC
DOHCIVIC's Avatar
Well if you go to your local parts store the make these small claps that you can squeeze two or three spring rings together to lower the rear
Old 03-29-2009, 07:59 PM   #7
xd69
1999 Honda Civic
xd69's Avatar
iTrader Rating: (1)
If you had shocks with adjustable spring perches, you could then just lower a perch to your liking
F*** Thieves...
xd69 is offline   Reply With Quote
Old 03-29-2009, 11:03 PM   #8
corkss
corkss's Avatar
i have gr2s!!
I heard about those clamp things...I 'll have to look into em! Thanks
03' Accord ex
I ♥ HONDA
Old 03-31-2009, 03:41 PM   #9
TunerN00b
TunerN00b's Avatar
i have gr2s!!
Be careful. If one breaks loose while driving the car, it can shoot off the spring hard enough to damage things (fender, wheel, tire).
Personally, I'd run cut springs before actually driving with a spring clamp in place, and I would never recommend cutting springs to begin with.
TunerN00b is offline   Reply With Quote
Old 03-31-2009, 06:14 PM   #10
corkss
corkss's Avatar
I'm not crazy about the clamp idea either. Anybody know the difference between itr and ctr springs, i have a b series motor, so wieght isn't an issue is it? HMO wants 150$ for ctr shocks and springs, I just bought new gr2s....uughh..
I want a 1" drop or less, what are my options everyone!
03' Accord ex
I ♥ HONDA
Old 03-31-2009, 07:22 PM   #11
Civichatch2k
Civichatch2k's Avatar
Send a message via AIM to Civichatch2k
Look into tein springs or maybe eibach springs? You will have to lower a little more than that I think but the only other options is to lower it one of two ways which will blow out the shocks most likely.
cut the spring or heat the spring.
I do not recomend either, just save your money and invest in a good researched based lowering spring and enjoy the satifaction of know that you invested in something that ultimately may save your life by doing what it was designed to do!
Just my .02
Originally Posted by -Gambit-
---Take pride in your car and build it dont buy it, daily drive it.---
Team Ikon
Vouches:
Ill Mitch, haccord2.2
Good Sellers: EL Vap133, Katman, klubhed1, Charlie Moua, Heylookits shawn, Padawan, dut, excivicboy96, haccord2.2
Civichatch2k is offline   Reply With Quote
Old 03-31-2009, 07:28 PM   #12
xd69
1999 Honda Civic
xd69's Avatar
iTrader Rating: (1)
Well its kind of hard to lower without changing the springs which will most likely increase the spring rate and end your "Going over railraod tracks now are a dream! " experiences.
The easiest way I see is to use a shock with an adjustable spring perch
F*** Thieves...
Old 03-31-2009, 07:46 PM   #13
corkss
corkss's Avatar
Any good aftermarket springs with a 1" drop or less?
03' Accord ex
I ♥ HONDA
Old 04-03-2009, 02:18 PM   #14
nonsense
nonsense's Avatar
H&R OE Sport will drop your car 0.75" front and back
http://www.tirerack.com/suspension/S...tegory=Springs
I don't own any more Honda's
nonsense is offline   Reply With Quote
1999, 99, back, civic, clamp, clamping, clamps, honda, loose, lower, lowered, lowering, rear, sits, spring, springs
