Blue smoke: new valve seals, compression & leakdown good. Why?
Old 03-25-2009, 08:35 PM
aasarsak's Avatar
Default Blue smoke: new valve seals, compression & leakdown good. Why?
Just replaced the valve seals, and rechecked compression. I got 225 225 200 235. Adjusted valves to .006" intake and .007 exh. set timing to 15*.
B16A
Still have blue smoke.
What could it possibly be?
Old 03-25-2009, 09:47 PM
lude98SH's Avatar
Default Re: Blue smoke: new valve seals, compression & leakdown good. Why?
Rings. A compression and leakdown test will only show the condition of your compression rings. Not oil control rings.
Old 03-25-2009, 11:11 PM
aasarsak's Avatar
Awesome.
What is the diagnostic procedure to confirm?
Old 03-26-2009, 06:47 PM
Scott_Tucker's Avatar
Generally, blue smoke during hard acceleration indicates faulty oil control rings. While blue smoke during deceleration and on startup after the engine has been off for a while indicates faulty valve guide sealing either from leaking seals or excess guide clearance. As a previous person said, a leakdown and compression test will tell you nothing about your valve guide seals or your oil control rings.
Old 03-26-2009, 09:47 PM
aasarsak's Avatar
Great, so it sounds like another crapshoot
Thanks for the info. I'm boosting anyway, so now might be a good time to upgrade my pistons...
Old 03-27-2009, 04:52 AM
lude98SH's Avatar
x2
Old 03-27-2009, 11:25 AM
aasarsak's Avatar
sea foamed it today to see if maybe that would make the smoke worse by removing the carbon buildup that may have been making it run fine so I could have a definitive answer as to whether it was the rings or not. No change. Idles slightly better.
I don't notice any smoke at all during acceleration. This is wierd because it seems to be contradicting what everyone has been saying.
Checked vacuum lines again. Turns out I had my PCV hooked up to a vacuum source that read 2 - 3 mmHg. Not enought to allow the crankcase to breathe.
I had switched it to another source that I thought was vacuum. I should have checked it BEFORE I switched it. Only reason I switched it was so I could run my BOV to a better source because it wasn't blowing off properly.
Funny thing is that now that I think about it, it only started smoking after I made the switch.
I hope it's not too late, but I put everything back the way it was before.
I fear that the inability of the crankcase to breathe may have caused damage to my rings already.
I tested the PCV valve. It is shot.
Will replace PCV, and repost results.
Really hoping to avoid replacing pistons.
BTW, I noticed that I was getting smoke out of my breather hose too. When I switched the PCV back the way it is supposed to be, it stopped, but I'm still getting smoke out of the tail pipe.
Old 03-27-2009, 03:38 PM
sikefcrx89's Avatar
rings sound done to me
Old 03-28-2009, 05:19 PM
aasarsak's Avatar
OK, this is becoming wierd.
Had somebody follow me, and the car only smokes after I decelerate and then punch the gas. No smoke under hard acceleration.
There was oil all inside my PCV when I replaced it.
Car is throwing a cloud of smoke once again at startup.
Vacuum test shows vacuum reading fluctuating vibration between 20 - 18 mmHg (occationallly, not constant)
And it smokes if I blip the throttle at idle.
Here is a shot of one of my valve guides.
If I remember correctly, I believe that 3 intake and 1 or 2 exhaust guides had this kind of scratch/gouge in them.
Old 03-28-2009, 05:28 PM
97hb's Avatar
You check the turbo??
Old 03-28-2009, 05:34 PM
aasarsak's Avatar
Yeah. No evidence of oil/tar/gunk/residue whatsoever either on exhaust or compressor side.
robertbaisley
02-14-2013 01:00 PM
EKk9
07-27-2011 03:04 PM
HybridBB6
05-14-2007 02:36 PM
andystart
14
10-15-2004 08:52 AM
Quick Reply: Blue smoke: new valve seals, compression & leakdown good. Why?
