Go Back   Honda-Tech > Honda and Acura Technical Forums > Tech/Misc
Old 03-22-2009, 09:22 PM   #1
revn9k
1994 Honda Civic
revn9k's Avatar
Icon6 HOW-TO: Manual Window Regulator install/replace
Well, I did a quick search and didn't see it. Really easy task, but this how-to could be helpful for those who are at it for the first time. This is one of several times I've done this, and it took me 20min. You can expect 30min to an hr. or so if you follow directions, don't run into probs(which everyone always does), and if it's your first time This documentation was done for an ek civic hatch.
Hope this helps. Pretty much applies to all Honda/Acura window setups for the most part.
(If power window, you'd unplug all wiring from pwr windows and door locks)
1. Remove tweeter cover plastic
2. Remove screw from door arm rest tray
3. Remove screw from behind door handle(you can see it when you pull handle to open door
4. Remove window handle(this is a little tricky - see pics).
5. Remove door panel(don't be shy, yank on it, only little plastic clips holding it in snug).
6. Remove 6 bolts, then 2 bolts that are kinda hidden and holding the glass to the regulator
7. Pull glass out and set aside, pull window regulator out and replace with new one
8. Reverse install.
9. Sit back, relax, and have a drink while being glad you saved some $$ instead of taking it to a mechanic!
Tools needed list: 10mm socket/ratchet, 10mm wrench,
needlenose pliers, phillips screwdriver, flathead screwdriver:
-Remove tweeter cover 1st; just pull on it:
-Remove phillips screw in armrest on door panel, pull plastic:
-Remove phillips screw behind door handle, pull out plastic:
-The stubborn pin that holds the window handle in place:
window handle removed:
-There's prob. a better way, but i used a flathead screwdriver
to pull the little metal hook pin that holds the handle on, then
needle-nose pliers to pull it all the way out:
- after the two screws are out(door handle and arm pocket) and window handle removed
then you just pull the inner door panel off. it has 4-5 plastic clips
holding it in like the one my finger is touching here:
Shows the 6 bolts of the 8 to be removed - marked with green paper
There are 2 more bolts on the bottom of the glass that can't be seen
as they are inside the door:
my pinky is touching the 7th bolt to be removed, 8th is parallel
and on other end of glass. I recommend you hold the glass like this as you
remove the 6th bolt(last outside bolt) so that the glass won't fall and
bust:
removing last of 6 bolts:
7th bolt to remove(attached to glass track):
Yank that regulator out(slides out of big hole in door pretty easily):
This is how the glass & regulator are connected inside the door; you
can now see the two bolts on the bottom of glass - these are the 2 of
the 8 i did not have marked in 1st pic:
Optional to remove/loosen this bolt to the window track; it helps
when putting the glass back on track(one track on each side):
Common rule of thumb for mechanics - don't tighten any bolts til
you have them all a little threaded. I put everything back together, then
tighten all the bolts:
- car worked on--> 96 ek civic hatch, 97k original miles d16y7, lowered
on skunk 2 coilovers, hx wheels, 2000 front end conversion, fog lights,
side markers:
revn9k is offline   Reply With Quote
Old 08-04-2009, 10:24 AM   #2
erikwithak
Default Re: HOW-TO: Manual Window Regulator install/replace
good write up helped me out ALOT thanks
erikwithak is offline   Reply With Quote
Old 02-12-2011, 01:39 PM   #3
bg1789
Thanks for the post - it was a big help! I used this to fix the driver's side power window on my 2000 Odyssey - a first time fix for me and this post was close enough to get me through the process. A few differences of note for anyone else who might be interested:
1. I didn't have to take off anything around the mirror.
2. I removed a screw from the inside door handle, 1 screw from the master power windows controls (each covered by a small cap that I popped off). I removed the inside door handle assembly and the power window assembly (which includes disconnecting them of course). I removed the screws around the speaker (I didn't have to remove the speaker from the panel - just make sure you disconnect it before yanking on the panel too hard).
3. After removing the panel, I had to peel back a white plastic cover that was almost like a tarp. I had to remove about 3 more screws to peel this back enough.
4. I removed 7 bolts to remove the regulator and motor plus 2 bolts that were on the bottom of the window. The 7 bolts were in roughly the same configuration as the ones shown here (2 low, 2 high, and 3 toward the front bottom of the door). The two window bolts were accessible through holes in the door panel, so you have to lower or raise the window to the right position in order to align them with the holes and reach them.
5. To lift the glass out I had to rotate it a little while it was still on the track, so the larger side (back side) came out at an angle first and the smaller side (front side) came out second.
Hope this helps anyone else who finds this post while fixing an Odyssey. Thanks for your help and pics revn9k!
bg1789 is offline   Reply With Quote
Old 02-22-2011, 01:29 PM   #4
j-r_rida
1995 Honda Civic
j-r_rida's Avatar
RoCcy_Miyagi RoccyEPG RoCcy_Miyagi
Thx for help
>>>Click--->My SLOW Build<---CLick
j-r_rida is offline   Reply With Quote
Old 03-26-2011, 10:32 AM   #5
e1ght4vii
1994 Honda Civic
My Garage
e1ght4vii's Avatar
i just did this on my gfs civic and when the window rolls up almost all the way it get off track what am i doing wrong? how do i know if the window is level or maybe do the tracks needs to b lubed?
e1ght4vii is offline   Reply With Quote
Old 08-03-2011, 12:27 AM   #6
92CivicHatchH23
1992 Honda Civic
whats up? so i have a 92 civic dx hatch and my driver manual window is really pissin me off. i bought a oem regulator and lubed the tracks very good lubed the bottom of the regulator just in case, and every time i roll the window up or down the front of the window by the mirror goes last and keeps throwing it of track if i dont help it. i was thinking about bending the track bracket but i thought i should ask first maybe someone can help. hopefully someone can help thank u.
92CivicHatchH23 is offline   Reply With Quote
Old 11-24-2011, 02:57 PM   #7
wek'lude
wek'lude's Avatar
Originally Posted by 92CivicHatchH23 View Post
...every time i roll the window up or down the front of the window by the mirror goes last and keeps throwing it of track if i dont help it. i was thinking about bending the track bracket but i thought i should ask first maybe someone can help. hopefully someone can help thank u.
Exact same issue I'm having, anybody find a cure yet?
1993 Prelude Si
2000 Civic B18C
wek'lude is offline   Reply With Quote
Old 01-26-2012, 02:05 PM   #8
kneelohowie
Had the same problem
There is a simple adjustment needs to be made so the window goes into place easily. The bolt holding the regulator closest to the back end of the door is through a slotted hole.
Loosen the bolt and slide the bolt part of the way towards the bottom of slot while holding the window, retighten and test by winding up window.
If still not right then repeat process until the window slides feely into the correct position.
On my daughters 92 Civic the bolt had to be right at the bottom of the slot.
kneelohowie is offline   Reply With Quote
Old 03-02-2012, 09:01 PM   #9
coolindagame304
Great write up I'm going to use this when I work on my teg but idk I have the same issue my window is power and if just falls down but it's on track
DNK #09
Altered WHIPS and BIKES Stay Fresh Crew
coolindagame304 is offline   Reply With Quote
Old 03-03-2012, 04:04 AM   #10
Stunna MIKE
Stunna MIKE's Avatar
king_mikey_
cant visualize what you are talkign about about.. any pics ?
FS! : 1995 Clean Title Honda Civic EX ABS Model w/ JDM H22 mFactory LSD & 5.1 Final Drive!
Originally Posted by beansandrice View Post
For less money that a k24 you can have a b16 and net the same power lol
Stunna MIKE is offline   Reply With Quote
Old 03-05-2012, 12:08 PM   #11
kneelohowie
Sorry, no photos.
Since sold the car.
Old 03-07-2012, 03:04 PM   #12
kneelohowie
Hey, got a photo showing the location of the bolt but cant work out how to post it here. Email me on lorney@xtra.co.nz and I'll send it to you.
Old 04-04-2012, 11:02 PM   #13
bigpunn421
bigpunn421's Avatar
can i replace a manual window regulator in a civic eg without removing the glass?
bigpunn421 is offline   Reply With Quote
Old 08-08-2012, 10:49 AM   #14
dvdomingo
How about an automatic regulator for an Odyssey passenger window. How do you replace it.?
dvdomingo is offline   Reply With Quote
Old 08-15-2012, 09:37 PM   #15
skadoner
Maybe you could help me out,I godda change my regulator but I've also godda change the pulley system, I'm but sure what its called. Its where all the wires that make the window go up and down go into. Its the little silver box that the window handle sticks onto. Could you help me out on how to change that?
skadoner is offline   Reply With Quote
Old 09-03-2012, 07:39 AM   #16
BearTransport
Great post! I used this months ago to guide me through my repair. Very little is different on a 2000 Honda Civic DX.
I'd like to post a howto for a 2000 Honda Civic DX (Value Package) manual window regulator replacement. Apparently I need to wait 15 days and post 5 times to upgrade my account before I can upload photos. Post 1 of 5.
BearTransport is offline   Reply With Quote
Old 09-26-2012, 07:00 PM   #17
stat3ofm1nd
stat3ofm1nd's Avatar
i need for power windows on a 98 civic 4 door dyi
stat3ofm1nd is offline   Reply With Quote
Old 10-27-2012, 08:11 PM   #18
Marcoscrdo
Does this work on a 96 civic dx? My manual passenger side regulator thing is really hard to turn at midway rising the window back up. Does this mean i need to replace the regulator or take out Greece lube up then reinstall?
Marcoscrdo is offline   Reply With Quote
Old 12-27-2012, 06:58 PM   #19
LadyCamouflage
1999 Honda Civic
LadyCamouflage's Avatar
endlessredproductions
If you're like me, you learn by taking things apart and learning how it all goes together. So take it out and look at it. This is coming from the chick with her Civic's door torn apart in her garage at the moment. Mine is power, so yours is a little more simple.
Taking it out is easier than it looks. Trust me. Just can't be afraid to yank the paneling off. It does come after awhile. I had to remove some screws that were hidden under the speaker horn and it came right off.
At least you know it's the regulator and not a regulator OR the motor. So yeah, Dude. Take that sucker out and see what works. Won't know until you try.
Also I learned that taking the track bolts out is a BIG help when putting the window back in line with the guides so it rises and falls in line. It's a lot easier to put the glass back in the rubber slits on the inside of the door that way and then bolt the track back down around it. If you do that, you shouldn't have an issue with re-aligning the window.
Drive It Like You Stole It.
https://www.facebook.com/EndlessRedProductions
LadyCamouflage is offline   Reply With Quote
Old 04-04-2013, 08:18 PM   #20
los94
1994 Honda Civic
My Garage
great info i just bot my car and the window is taped but i shud be getting the two missing window bolts tomorow and get it all ready!
los94 is offline   Reply With Quote
Old 12-29-2013, 01:08 PM   #21
KPDSM
I have been using this as a guide for my power window in my 96 sedan. I took everything apart, and couldnt determine whether it was the regulator or the motor, so I grabbed both off amazon. Hopefully when it comes ill be able to figure out how to get it baxk bolted up. When it comes ill return with update
KPDSM is offline   Reply With Quote
1994, 2001, civic, dx, ek, guide, handle, honda, install, installation, odyssey, power, regulator, removal, window
