Go Back   Honda-Tech > Honda and Acura Technical Forums > Tech/Misc
Old 03-18-2009, 06:19 PM   #1
WheelPowerRacing
1994 Honda Civic
WheelPowerRacing's Avatar
Send a message via AIM to WheelPowerRacing
Default Acura Integra & 92-95 Civic injectors interchangeable?
I am building a LS/VTEC using a GSR head & bare GSR stock intake. I am trying to utilize parts already in my possession (my build is way over budget!) and my question is can I use a set of 1994 Civic (D16Z6) injectors I already have? I think they are both 245cc? Both are OBD1. Any information would be helpfull. Someone said I needed GSR or Type R injectors for performance reasons. Is there a difference? I have a stock B16 fuel rail and pressure regulator that appear to be usable with the GSR intake also.
WheelPowerRacing is offline   Reply With Quote
Old 03-18-2009, 06:26 PM   #2
non-VTEC
1995 Acura Integra
non-VTEC's Avatar
Default Re: Acura Integra & 92-95 Civic injectors interchangeable?
you can use those injectors no problem. they are exactly the same.
95 Integra Turbo - SOLD
2014 Toyota Corolla S
non-VTEC is offline   Reply With Quote
Old 03-19-2009, 06:15 AM   #3
Fibercation
iTrader Rating: (5)
Send a message via AIM to Fibercation
what he said^
Originally Posted by Sonin Fury View Post
"blacklist" of not-giving-everything-away-to-lowballing-honda-****** you mean?
Yes I think he is on that one.....
Fibercation is offline   Reply With Quote
Old 03-19-2009, 11:37 AM   #4
WheelPowerRacing
1994 Honda Civic
Thanks, the build continues!
Old 03-19-2009, 06:38 PM   #5
WheelPowerRacing
1994 Honda Civic
Took the injectors from the D16Z6 intake I had and the bottom seals and they fit. The bottom seals out of the newer B16 intake i had were about 1/2 as thick and set too deep. I knew the D16Z6 fuel rail would not work as the injector spacing is greater on the GSR manifold. So I used the fuel rail from the newer B16 intake, but it set too high with the 3 mounting spacers. I removed the spacers and it seems to fit/work. Question is, what is the purpose of the plastic spacers and am I setting myself up for trouble by mounting the fuel rail without them? I would hate to have high pressure fuel spraying all over my hot freshly rebuilt engine.
1995, 9295, acura, civic, fit, fuel, gsr, honda, injector, injectors, integra, interchangeable, kind, ls, rail
