Gas pedal slightly pressed = knocking sound
Old 03-14-2009, 06:56 PM
2a5x1's Avatar
Default Gas pedal slightly pressed = knocking sound
1993 Honda Accord LX. I'll be cruising down the road anywhere from 40-70 MPH in 4th or 5th gear. I'll slightly press the gas pedal and hear a rapid knocking sound from somewhere between the clutch and gas pedal on the engine side of the firewall. This is only heard when the pedal is slightly pressed, further increasing/letting off pedal sound goes away. My room mate's mid 90's Accord is doing the same thing. Is this a common problem? I tried searching for past threads. Could someone please share a corrective action ?
Old 03-14-2009, 08:40 PM
dtapia's Avatar
Default Re: Gas pedal slightly pressed = knocking sound
possible rear motor mount since it is vacuum operated. follow the vac line off the fire wall and disconnect at the solenoid and retest .
Old 03-15-2009, 11:41 AM
CG6Accord8o1's Avatar
cv joint?
EAF2014
Honda Accord (2013 - 2015)
02-02-2018 04:54 AM
itr1244
07-15-2016 07:49 PM
Tenassi
Honda Civic (2001 - 2005)
09-02-2013 12:58 PM
B18C_DC2
11-03-2009 04:35 PM
allergymeds
Honda Civic (2006 - 2015)
08-20-2009 07:19 AM
Quick Reply: Gas pedal slightly pressed = knocking sound
