How to reset the CEL (Check Engine Light)?
Old 03-14-2009, 10:34 AM
phoenix_iii's Avatar
Location: Close to West Chester, PA, United States of America
Icon2 How to reset the CEL (Check Engine Light)?
This one is for the FAQ, I hope
How does one properly reset the CEL?
In this case, a 91 CRX HF.
I searched HT, and other sites as well. =( It takes more than the ECU Fuse (15am under the hood)... Hazard fuse? =\
*edit*
Hazard Fuse for 10 Seconds as per the Honda Service Manual!
*/edit*
(This does not include pulling the battery. I would, but I have the stock radio, and do not feel like pulling it right now, losing radio presets, and I have to fix the climate control and cannot get into that now, etc)
Old 03-14-2009, 11:08 AM
chwkef's Avatar
Default Re: How to reset the CEL (Check Engine Light)?
two options.
Pull the negative battery terminal off for a couple minutes
Pull one of the fuses in the underhood fuse box for a couple minutes. Only problem is I can't remember which one It's a 10 amp in my 90 Hatch
Old 03-14-2009, 11:12 AM
jlicrx's Avatar
just remove the hazard/ECU fuse from the underhood fuse box for 10 seconds - top fuse in back row closest to firewall
Old 03-14-2009, 11:14 AM
Ah. I pulled the ECU fuse (15amp) but it still remembered the code. The Hazard fuse I think serves as the memory for the ECU.
I'd just like this to be documented! I will try that, but the ECU fuse alone doesn't cut it.
Old 03-14-2009, 11:20 AM
chwkef's Avatar
ahhh that's what it was. haha. thanks
Old 03-14-2009, 11:39 AM
frank_el_tanke's Avatar
that fuse is all you need to reset the computer. however, you might have not fixed the problem and that's why your cel keeps coming back... what codes are you getting.
Old 03-14-2009, 12:11 PM
Don't need to turn this into a troubleshooting thread, but I appreciate your concern. I have another thread here ( https://honda-tech.com/forums/showthread.php?p=37761684 ).
The darndest thing is that now my CEL blinky LED (located in passenger foot well) is blinking without the paper clip, for the two codes mentioned (1 and 12, and 1 went away with the new o2 sensor from 2 months ago, and 12 went away with seafoam...). I need to replace fuel filter (this weekend!). See the other thread, this thread was just about resetting the code!
Hazard here I come!
Old 03-14-2009, 05:01 PM
Editing main post
9civic8
04-02-2004 08:51 AM
SiFactor
08-29-2003 07:01 AM
NoLipRacen
01-29-2003 05:16 PM
SIK IN DA HED
10-27-2002 08:42 PM
Spade
01-14-2002 10:29 AM
Quick Reply: How to reset the CEL (Check Engine Light)?
