'92 DX misfire/sputtering at low RPM after warm up- I'm friggin stumped.
#26
1 Post
Re: '92 DX misfire/sputtering at low RPM after warm up- I'm friggin stumped.
looks like a few of us are having the same exact issue almost "mine doesnt smoke but everything else is to the point"
but i have a question for all of u guys... while the car is sputtering through the powerband, does it seem to pull right through it if u floor the gas pedal..?? Mine well sputter if im like half throttle, but if i slam it it just scoots right through like no problems at all...
im tryna see if we can actually figure out what the issue is, i was leaning towards intake manifold gasket where the coolant line is at... matter a fact, im goin to go work on it right now an see if we cant resolve this damn 92 civic dx issue lol..
#28
Interesting you mentioned the intake manifold gasket- when I removed the head, the intake manifold gasket was fried. Stuck to the intake manifold like old stickers stick to wood.. had to scrap and chisel with a putty knife just to get it off. I didn't think anything of it at the time.
#29
yeah, exactly, if i floor the gas pedal it runs fine. but i dont drive full throttle when i daily drive. i forgot to mention i swapped in a 99-00 b16 motor in it. people have told me it might be a vacuum leak. i have an open port on my short ram, can that be it? i've also been told that i might be running rich.
i have no clue...
#30
remember just because the car burns oil it doesnt mean its the bottom end..valve seals in the head can also cause oil burning..and if you've been overheating it its possible that you've caused some damage to the seals..
#31
The bore was worn slightly, enough to catch your fingernail on- mostly on the thrust side of the bore. We didn't bother doing a re-bore, so most likely it'll start burning oil again at some point. Guess i'll have to sell the car before then. Anybody wanna buy a '92 Civic DX? haha
It's a real shame old dude didn't change the oil/filter a few more times, it only had 93k miles on it and one owner when i purchased the car- a 70 year old man.
ANYWAY. New rings are in, pistons are re-installed. Gave up for the day, should have the car back together on my next day off. Inspected the block and the head, couldn't find any cracks- crossing my fingers that the overheated headgasket/re-used headbolts were the problem. Damn sure hope the $150 i had to spend for 10 more headbolts was worth it. I'll keep everybody informed- should have the car back together within the week- hopefully the sputtering is gone.
PS: I don't think it was on this site, but someone told me a full piston ring job could be done in one day.. Granted I had to buy some tools, and wait for parts to arrive but still, i'd have to see it to believe it :p
#32
Well, the car's all back together and running again. Looks like the headgasket was causing the sputtering- car runs nice and smooth for the most part, still stalls when idling under load, but the sputtering and misfiring is gone. I think the distributor timing is off, and that combined with tighter piston rings + 30 weight base oil (till rings are seated) is the culprit... either way, the sputtering is gone :D :D :D
#33
Nope.. adjusted distributor timing, still stalling. No more sputtering, no more misfiring, just loses rpm and stalls when stopping. One problem out of the way...
#34
Day off work tomorrow, looks like we're back to square 1- the IACV. Sputtering is gone, misfiring is gone, burning oil is gone, oil mixing with antifrize and vice versa is gone... everything's back to normal except the damn stalling.
So far I've fixed the bad O2 sensor, blown headgasket, and worn piston rings- now on to problem number 4.
There's an important lesson to be learned here.. CHANGE YOUR DAMN OIL! Too bad the guy I bought my car from hadn't learned it yet.
Benjamin Caley
12-21-2016 05:40 AM
Richarddrrr
06-26-2014 07:10 PM
dubtecv2
02-26-2010 12:27 PM
