#1 | |||||
Michael "Do the best you can with what you have" View my cars for sale. http://s276.photobucket.com/albums/kk1/exoauto/ |
#2 |
Sanji
Nice DIY write up.
#3 |
I used small needle nose pliers to get my c clips on my ball joints. But the c clip pliers would have been easier since it holds the clip open.
#4 |
Nice writeup. It's very helpful to wedge a jack between the frame and the lower control arm to relieve the tension on the system. Makes it much easier to reinstall the knuckle.
#5 |
Added to the FAQ's.
#6 |
Thank you, yeah i tried messing with the C clip but i left it alone after a couple failed attempts. my luck i would damage the new boot, lol.
#7 |
So after getting the C clip in I went to putting it all back together. FAIL The darn grease fitting is to tall for the axle to slide in. The ABS ring gets caught on it. Since I already greased the ball joint i went ahead and left it off. grease didnt come out through the top after installation so i guess it will work for now. im going to try to find some shorter fittings next time i go to autozone.
#8 |
Is this on an EP3 or EM2?
Anyway, got a question about the original ball joint. Was there a C clip on the original one? Or just the aftermarket one? I may have gotten the wrong ball joint for my Del Sol but looks like it might work on my RSX. The ball joint I have is shorter than the one for my Del Sol but looks like the one in your pics. |
#9 | |
Sanji
Non-EP3, because this isn't the EP3 forum. |
#10 |
very nice diy write up i just wanted to share this with you. its a s/b from honda about the ball joint. it has you look at a stamping mark on the ball joint. depend on what you have youmay need to replace that knuckle because repalcement balljoint doesnt fit correctly in the hole and will pop out. ive seen it happen before and it could get ugly.
#11 |
Has anyone treed removing the ball joints without removing the knuckle/hub assembly. I have to do mine tomorrow but im trying to remove as least as possible. I was thinking just hitting it with a hammer to get it out of the knuckle,then use either a no-bounce hammer or a c clamp to get the new one in the knuckle.
#12 |
Yeah, I figured it out afterwards when I noticed the tranny wasn't on the driver's side.
Anyway, to the OP, you said you got the ball joints at Autozone? What brand of ball joints? I have a theory these would work in the 02-04 RSX. |
#13 | |
i dont remember the brand bj i used. i just asked for them and they gave em to me.
#14 | |
Or you can use a vise if you don't have a C-clamp |
#15 |
hey i installed these today but forgot to put the little grease L-shaped things on, is this gonna make a difference? i tried to screw them on afterwards but there's not enough room to get them in, the axel's in the way. how important are these? I noticed that the ball joint has grease in it already.
also did lower control arm bushings. frustrating. finally took em to a mechanic to have em pressed in. next time maybe just would buy new arms. last week i put 4 new struts in. right now i never want to look at the inside of the wheel wells again haha. |
| Bookmarks |
| Tags |
| 05, 2004, acura, ball, bearing, bearings, civic, honda, joint, pilot, removal, replace, replacement, rsx, tl, wheel |
