Old 03-03-2009, 12:34 PM   #1
sde780
sde780's Avatar
Send a message via AIM to sde780
Default Sloshing sound
I've noticed a sloshing sound everytime I drive. It's very consistent, everytime I drive off it sounds like water's running out of a hose or something.
Today I did a test, put it in N and kept it at 1500 rpms, keeps hearing that sloshing sound. The car isn't moving though.
Anyone got an idea as to what it may be?
2012 Tacoma DCLB
https://www.youtube.com/user/shengdama?feature=mhee
sde780 is offline   Reply With Quote
Old 03-03-2009, 12:55 PM   #2
RonJ@HT
Raising the bar
2000 Honda Civic
My Garage
RonJ@HT's Avatar
Default Re: Sloshing sound
Air trapped in the cooling system and heater core? Check whether the coolant level is low in the radiator and reservoir.
Old 03-03-2009, 12:59 PM   #3
pumafeet10
1997 Honda Civic
pumafeet10's Avatar
Send a message via AIM to pumafeet10
most likely water running through your cooling system into your heat core/ ac
NO MAS Accord
now 00 Hatchy" The Lobsta"
And nao no more lobsta
pumafeet10 is offline   Reply With Quote
Old 03-03-2009, 01:04 PM   #4
sde780
sde780's Avatar
I hear it more when ac/heat is on, so that makes sense. How do I fix it, drain all the coolant and refill?
2012 Tacoma DCLB
Old 03-03-2009, 01:09 PM   #5
sde780
sde780's Avatar
I just checked it, the overflow container is wayyy below the "low" line, should I add more antifreeze?
2012 Tacoma DCLB
Old 03-03-2009, 06:23 PM   #6
RonJ@HT
Raising the bar
2000 Honda Civic
My Garage
RonJ@HT's Avatar
When the engine is cold, top off the coolant in both the radiator and the reservoir. Then bleed the system as detailed in the service manual.
Old 03-05-2009, 04:43 PM   #7
sde780
sde780's Avatar
Thank you, I'll do it tomorrow. Would that make any difference in performance at all? I've been getting 22 mpg for a while now and I can't seem to figure out what's wrong...my dad hasn't done anything to this car for 3 years now - only oil changes.
2012 Tacoma DCLB
Old 03-05-2009, 04:50 PM   #8
RonJ@HT
Raising the bar
2000 Honda Civic
My Garage
RonJ@HT's Avatar
It's possible. If air gets trapped around the coolant temperature sensor under the distributor, then the ECU will receive false temp readings that could might make the engine run rich.
2009, accord, acura, back, civic, del, honda, makes, noise, sloshing, slushing, sol, sound, sounds, water
