Go Back   Honda-Tech > Community Forums > General Discussion Forums > Photography
Old 02-25-2009, 06:05 PM   #1
NazVil86
NazVil86's Avatar
Send a message via AIM to NazVil86
Default My Ways Of Editing- Cleaning up, Layer Masking, Dodging and Burning, Sharpening
Well I started wanting to write out a tutorial about just merging photos- but didn't have a way on just doing that
So instead I'm basically showing my whole process from Start to Finish on one of my photos I had chilling on my computer.
Now I'm not writing this expecting to get "oh wow your awesome", "wow that totally sucks", "pics look like shit", "best article of the year"---But all the things I did on this one picture I learned over a period of time, each -technique I guess- I learned from someone else and I just put them all together and its how i do my work. Now granted I don't do all these things all the time in each of my pictures. But its just to show samples and step by step on how to do these type of things.
Hope you Enjoi
Here we go here's a first look at everything ill be doing- minus the fixing the corner light, i got lazy sorry
I start off with the small stuff first- which for me would be removing the little flash flare in the sky
I forgot to put- after this step of using the patch tool- i used the healing brush to smooth out the area
Checking off the list- no more flare wohoo, pft like that was hard
Ok so my lighting placement on this shot sucked hard so I got that catch light right there on the door- and it brought out a lot of the paint swirls and imperfections and what not. Now i cant totally remove that catch light- but we can smooth out this area out a bit
To get this result i just zoomed in a good amount- past 100% and started using the healing brush tool. Its like the clone stamp tool- but I'm not gonna lie, i have no idea what the difference is on the two lol. to me they kinda do the same thing but the healing brush is smoother hah
Now we get to how to layer mask. I want the ground in this shot to look a little more..."gritty"? If that makes sense to anyone. I want it darker and to have some depth to it- because it really looks flat here.
To start off I will duplicate the background layer
Than make my adjustments accordingly- which shows in the next frame. lets move on to that shall we?
Basically I messed around with the color balance- upped the blues, turned down the reds in each section except I don't think I touched the shadows. I also messed with the Levels a bit.
Here's how we do a layer mask- which is how i merge my layers- follow along now kiddies
Here's after i re-touched up the ground layer again- needed to be a bit more darker than i originally planned on but I like it
Now I forgot to do screen shots while I was editing the rims. In the description in the picture I just want to make sure you all get this. I duplicated my base layer- went to Image > Adjustments > Color balance and started to play around with the sliders. Yes it does affect the entire picture- but just look at the rims, since that's the area that's important here. I got the bronze tone i liked- than hit OK. I now have a whole picture that looks "orangey bronze". Do the layer mask- and just draw in the rims- that easy. You don't have to use the lasso tool- and do all these other things- For me drawing it in is easier. I ended up lowering the opacity for the layer after wards since the bronze looked to orange. But the next images cover my dodging and burning method vs just using the dodging and burning tools in Photoshop
Ok the light flare is gone, I smoothed out the passenger side swirl marks and what not, I adjusted the rims to pop a bit more, I adjusted the ground for some depth, I brightened up the front end (for this i opened up the original raw file- stepped up the exposure a bit- and brought that layer onto this file- using the layer mask- drew in the selected area up front in this picture- than lowered the opacity so it wasn't so bright- sorry I didn't cover that also but that's how I did it, very subtle change but it makes a difference)
To remove my camera bag- just zoomed in and used the clone stamp tool- the healing brush will not work here- it wasn't bad I just went with the lines on the ware houe as a guide line
This part to get the sky and warehouse touched up I did the following
Duplicate the layer *get used to doing this from the start*, Desaturated the layer- and played with levels and what not. Then layer masked and drew in the sky only.
Duplicated the layer, Played with selective coloring on the cyan option so it could be a nice deep green like the warehouse really was, than layer masked and drew in only the warehouse. And here we are now
Now if you have your own sharpening method- you don't have to follow these next steps. My friend showed me this method since I personally cant get the hang of using the USM method. So if you don't mind trying something new keep reading. I'm not saying this is better than USM- any way you get your image sharper, and you feel comfortable working with do it.
For the radius I will usually go up to 25%-35%
Thank you for reading this, If you have any questions or comments please post up or PM me. Again like I said in the beginning- if your reading this and saying "wow this guy did it all wrong" that's fine, there are hundreds of ways to do things in Photoshop, this is merely the way I get things done, I feel comfortable doing, and works for ME.
Larger version of final product
DC Squad Member #69
1994 Integra- working on it
NazVil86 is offline Report Post   Reply With Quote
Old 02-25-2009, 07:22 PM   #2
CRX_VTEC
CRX_VTEC's Avatar
Default Re: My Ways Of Editing- Cleaning up, Layer Masking, Dodging and Burning, Sharpening
super nice write up! Props for taking the time.
CRX_VTEC is offline Report Post   Reply With Quote
Old 02-26-2009, 05:20 AM   #3
ne3ek
ne3ek's Avatar
i picked up a couple tricks, thanks.
13203
cars.cameras.bikes
ne3ek is offline Report Post   Reply With Quote
Old 02-26-2009, 07:29 AM   #4
RedStarGsr
RedStarGsr's Avatar
Send a message via AIM to RedStarGsr
nice write up man.
this little tutorial thing takes 'forever' im sure to put together but a lot of people can really learn from it. Hell, i didn't learn any tricks until I started going through these types of tutorials!
We use a lot of the same techniques, haha-- did you try to get rid of the flash hot spot though? I'm sure you could...
*dan l bmw m5 l cbr 929rr
*Flickr
*dkfx Photography <-- my site!
RedStarGsr is offline Report Post   Reply With Quote
Old 02-26-2009, 07:32 AM   #5
jonshonda
jonshonda's Avatar
Really good write-up!! Makes HT a better place when members put this much time into their work
/Oo ___H___ oO I ♥ RECARO
|=_/________=| // Nikon D40 18-55
I ♥ my Honda
DC Squad Member # 0494
jonshonda is offline Report Post   Reply With Quote
Old 02-26-2009, 10:59 AM   #6
NazVil86
NazVil86's Avatar
I am going to clone it out
AND I know the steps on the pictures themselves have a bunch of typos, I was on my meds and made me kinda sleepy- but knew I wanted to finish this or I would've put it off for another few days.
I am in the process of cloning out that hot spot.
Im glad some of you took something from this, and if I can think of anything more- ill post a few things up here and there. I really wanted to try doing video- But I heard to get real good quality you'll need a capture card? or something, oh well later on.
I can maybe do a tutorial on lighting setups with video though....dont let this hot spot fool you- usually i dont get a lot of hot spots haha. i swear.
DC Squad Member #69
Old 02-26-2009, 11:05 AM   #7
JDMxTi
JDMxTi's Avatar
Send a message via AIM to JDMxTi
good stuff man, currently trying out a few things from this.
JDMxTi is offline Report Post   Reply With Quote
Old 02-26-2009, 11:10 AM   #8
RedStarGsr
RedStarGsr's Avatar
i have a program that's mega easy to use to 'record' what you'er doing it on screen, and the thing will even upload it to their server. our trainer uses it at work, when he gets back from lunch i'll hit you up playboy.
*Flickr
Old 02-26-2009, 11:13 AM   #9
NazVil86
NazVil86's Avatar
awesome man, id love to try doing little things, maybe like skin touch up for portrait work
and maybe on set clips of where i place my lighting and how to balance ambient with flash- i know most know, but it'd be good to see on video. Hm.
DC Squad Member #69
Old 02-26-2009, 12:27 PM   #10
RedStarGsr
RedStarGsr's Avatar
jing by techsmith.com
check it out
*Flickr
Old 02-26-2009, 12:28 PM   #11
RedStarGsr
RedStarGsr's Avatar
skin work
: select
: color range
: select face
ctrl j ctrl J (two layers)
first layer surface blur 20/20 settings
second layer other- high pass, soft light (or overlay) i forgeto
then player w/ the mixtures of opacity
*Flickr
Old 02-26-2009, 12:40 PM   #12
NazVil86
NazVil86's Avatar
do a writeup lazy mo fo lmao
DC Squad Member #69
Old 02-26-2009, 12:41 PM   #13
sik_one
sik_one's Avatar
Very good write up! Props to you mang.
sik_one is offline Report Post   Reply With Quote
Old 02-26-2009, 01:54 PM   #14
just Touge
just Touge's Avatar
There is still lens flare on the car.
Flickr | EK Squad | Nikon | GD
just Touge is offline Report Post   Reply With Quote
Old 02-26-2009, 02:17 PM   #15
NazVil86
NazVil86's Avatar
blah blah blah
thanks sik_one
DC Squad Member #69
Old 02-26-2009, 05:03 PM   #16
Kyle is raaddd
Kyle is raaddd's Avatar
thanks, i picked up some techniques i didn't know before
My Flickr
Originally Posted by Rude Awakening View Post
i accidentally a daughter
Kyle is raaddd is offline Report Post   Reply With Quote
Old 02-27-2009, 05:01 AM   #17
OneOhNine27
OneOhNine27's Avatar
Send a message via AIM to OneOhNine27 Send a message via MSN to OneOhNine27 Send a message via Yahoo to OneOhNine27
Holy crap!!!
STICKY MATERIAL FTW!!!
'99 VSM Hatchback.
NikonEquipped.
Originally Posted by Morasso View Post
because im from japan, and the chassis code for 96-00 civics is actually STFU....
OneOhNine27 is offline Report Post   Reply With Quote
Old 02-27-2009, 08:34 AM   #18
TouringAccord
H-T Order of Merit
TouringAccord's Avatar
added to the Tutorials section of the FAQ thread
TouringAccord is offline Report Post   Reply With Quote
Old 02-27-2009, 08:41 AM   #19
NazVil86
NazVil86's Avatar
wohooooo
DC Squad Member #69
Old 03-01-2009, 09:02 AM   #20
jokercykoe
Late to the game
jokercykoe's Avatar
thanks!
jokercykoe is online now Report Post   Reply With Quote
Bookmarks
