Old 02-21-2009, 08:26 PM   #1
umair
umair's Avatar
Default is it bad that my car runs too cold??
i got a h22a swap in my del sol and when it is cold outside my temp needle does not even move. if i drive it for at least 30 min it will go up but it wont even get to the first line. i read somewhere that sometimes its bad when your motor runs too cold but many people say that its good that you motor runs cool. a few weeks ago it was in the 60s and i took my car out and the temp did go to the halfway point but my car felt a lot slower(it should). i know its good if your motor runs cool but my motor runs a little bit too cold, lol. is it anything thats wrong or is it a good thing??
thanks
umair is offline   Reply With Quote
Old 02-21-2009, 08:30 PM   #2
RonJ@HT
Raising the bar
2000 Honda Civic
My Garage
RonJ@HT's Avatar
Default Re: is it bad that my car runs too cold??
It's not good for the engine to run cool. The ECU will force the engine to run in a preprogrammed mode that uses excess fuel (rich). Replace the thermostat because it seems to be stuck open.
Old 02-21-2009, 08:56 PM   #3
umair
umair's Avatar
do you think it is affecting the performance of my motor too???
Old 02-21-2009, 08:58 PM   #4
RonJ@HT
Raising the bar
2000 Honda Civic
My Garage
RonJ@HT's Avatar
Yes
Old 02-21-2009, 09:00 PM   #5
lcsej1
lcsej1's Avatar
Send a message via AIM to lcsej1
the computer will see your car as if it was warming up so itll run a special start up program like ronj@ht said. if it's cold it won't achieve stoichiometric(perfect air/fuel mixture.
lcsej1 is offline   Reply With Quote
Old 02-22-2009, 12:04 AM   #6
Drsexiestboy
1994 Honda Accord
My Garage
Drsexiestboy's Avatar
Send a message via AIM to Drsexiestboy
I have the same problem but with a b16a would this also cause vtec to open very low...
Eg6: B16A(SOLD)
Db8: LS(PROJECT)
Drsexiestboy is offline   Reply With Quote
Old 02-22-2009, 12:29 AM   #7
hoffmanb16
hoffmanb16's Avatar
also get a aftermarket temp gauge, way more accurate.
hoffmanb16 is offline   Reply With Quote
2001, bad, car, cold, cool, crv, engine, gauge, honda, motor, run, running, runs, temperature, transmission
