89 honda accord shaved downpipe bolt
the bolts where the exhaust manifold connects to the downpipe from under the car bolt got shaved....and its a bitch/tight squeeze to get a vise grip out ...its a #14 any ideas in what i got to buy now and which was would be the best and easiest
Re: 89 honda accord shaved downpipe bolt
Craftsman sells a bolt-out kit. Basically its a kit consisting of a couple universal sized nut/bolt removers. You just hammer on the bolt-out over the rounded bolt/nut and then use a larger socket to turn it out- the bolt/out has a reverse thread that helps it grip as you turn it.
Although on downpipe bolts the clearance for a larger socket is almost none (sometimes its hard enough just getting the 14mm in there). The other type of bolt-out tool is the one where you drill the a hole in the old bolt, and then tap a square shank into the hole and then turn it out.
-If neither of these work for you, then its time to get out the torch and cut that bitch out! haha
StolenTeg
08-24-2005 02:46 PM
Rod.
06-03-2004 07:36 PM
