Old 02-14-2009, 10:07 PM   #1
redline870
redline870's Avatar
Default Car shakes at red lights???
when i come to complete stop at red lights my car shakes. if i shift it into park and let off the brake then it wont do it anymore. its a 96 accord lx with a jdm f22b engine and tranny. any idea why it would do that?
redline870 is offline   Reply With Quote
Old 02-15-2009, 12:24 AM   #2
jwicecold
jwicecold's Avatar
Default Re: Car shakes at red lights???
It could be a few things, most are pretty easy fixes.. Does it have a check engine light on?
One your idle could be to low and your car is struggle to staying idle so it shakes about to die..
Two your valves could need to be adjusted.. This a little more tough to do, have to read up on that.
Three your idle control valve could be functioning improperly..
jwicecold is offline   Reply With Quote
Old 02-15-2009, 12:27 AM   #3
redline870
redline870's Avatar
but it only does it when its idleing in drive, not when its in park or neutral.
***1993 del Sol Si - B18C Type R***2004 Acura TSX***
Beat it, Break it, Wrench it, Repeat!
Old 02-15-2009, 04:18 AM   #4
kjmoy
kjmoy's Avatar
Try cleaning the IACV first. It is easy to do. Follow the following link. Honda 5th gen is almost exactly the same as Integra. It can't hurt.
http://www.team-integra.net/sections...ArticleID=1174
kjmoy is offline   Reply With Quote
Old 02-15-2009, 05:22 AM   #5
P_Adams
P_Adams's Avatar
You've most likely got a broken motor mount. It's usually either the front or (but most often) the rear.
What's happening is that the torque produced at idle is enough to twist the motor in the opposite direction. With a broken mount, the engine isn't restrained as it should be and can start vibrating or pressing against something it normally wouldn't.
The reason no vibration in neutral? No Torque to twist the engine.
Being a '96 Automatic, it will most likely be the rear mount. It's vacuum assisted and does this with a disturbing frequency.
P
#1 '97 CD7 SE Accord Coupe San Marino Red / #2 '96 CD7 LX Accord Coupe Arctic White / #3 '96 EJ8 EX Civic Coupe Black / #4 '88 LXi Coupe (spare)
One more "What's the Top Speed..." thread and I think I'll flame someone
P_Adams is offline   Reply With Quote
Old 02-15-2009, 01:07 PM   #6
redline870
redline870's Avatar
P
that was more the response i was looking for, something that makes sense. if it was the iacv then it would do it whenever it idles, not just in gear. i replaced the front mount when i did the swap. ill put the car on one of the drive-on lifts at work and have someone sit in it and shift it into gear to check the rear mount. thanks yet again P_Adams
Old 02-15-2009, 01:10 PM   #7
CanadianEh48
CanadianEh48's Avatar
torque converter not disengaging from full lock?
1991 Accord LX, Short Ram Intake, 17" Motegi FF5 Rims
2 10" Infinity Subs, 1000W Clarion Amp, Pioneer Deck
CanadianEh48 is offline   Reply With Quote
Old 02-15-2009, 01:14 PM   #8
redline870
redline870's Avatar
the car wont even shift into full lock. ive had a problem with this ever since i did the swap. at 75mph the rpms are at 3300. if the torque converter wasnt disengaging then wouldnt it accelerate/drive wierd at low speeds? the engine/tranny came out of a jdm odyssey so im wondering if this may be why im having issues with the tranny. im using the original usdm ecu with the jdm engine and tranny.
im starting to think that maybe the full lock issue, and shaking at stops in gear might be related?
Old 02-15-2009, 03:53 PM   #9
CBL9
CBL9's Avatar
Send a message via AIM to CBL9
Motor Mount, I had a simliar issue in my 1993 Accord. I just replaced the front one, all is fine now.
2008 Pilot EX-L - Boat Hauler - Nimbus Gray Pearl
2007 BMW 335i - Weekend Toy - Crimson Red Clear
2006 Accord EX-L - Daily Driver - Alabaster Silver Metallic
1993 Accord SE - Winter Beater - Cashmere Silver Metallic (213K reliable miles)
CBL9 is offline   Reply With Quote
Old 02-15-2009, 05:14 PM   #10
redline870
redline870's Avatar
front mount is brand new. ill check the back one tomorrow and let u know how it goes.
Old 02-15-2009, 06:10 PM   #11
P_Adams
P_Adams's Avatar
GM had that problem with their first batch of Chevy designed TH700R4's. D**m things would stall when coming to a stop; every time.
Would act like you forgot to release the (std trans) clutch when stopping.
P
accord, assisted, b18c, car, engine, gear, honda, idle, lights, motor, mount, rear, red, shakes, vacuum
