Suspension noise?
Suspension noise?
Hey what up HT, I droped my car 2 inches with Tokico Blues and Neuspeed springs. I've been on this step up for about three months now, and all of a sudden now when I turn my wheel all the way to the left or right, as if I'm trying to back out of a parking space or my driveway it makes a little "poping/bumping" sound. Its not associated with accleration or anything, just when I turn the steering wheel all the way. Its also only the front left side. Any help will be appreacted. Thanks!
Re: Suspension noise?
I had the same problem you did when i lowered my car with skunk 2's on tokico blues ...Your strut bearings are probably busted... replace them and the noise will go away ... it worked on mine
http://www.autopartsplace.com/carpar...t-Bearing.html
This strut bearing fits the factory top hat perfectly
hey did the noise go away?
I'm getting the same problem. My mechanic said a part of the steering rack which is a mount is busted.
Anyone can elaborate?
I dropped my car about 8 months aback with tein s tech.
the people at the tire place replaced my strut bearings for me already and the noise is still there sometimes i think you do have to loosen up the bolts on the top and jack the car up and realign it like how 01 civic said
It makes the noise when car is in motion and sometimes when at stand still.
Also the suspension guy said that my F and R engine mounts needs changing and the 2 big front cradle bushings.
Also the bushing in the steering rack needs changing.
Anyone can elabotate?
i just took mine apart and put it back together and it went away, every once in a while it will make noises or pop, but after a few minuets they go away
Well, I have a pretty similiar situation with the popping noise while I'm driving. I'm pretty sure it's my axle (speedbump).. because I bottom out everywhere ..and I ruptured my cvboot..Hopefully after getting that issue fix the popping may go away.
Yeah you might want to get that fixed. Assuming that it is one of your front axle's you are talking about it is easy as hell to replace. I tore my CV boot when I was putting in my TEINs so I just replaced the axle. It was like between 50 and 60 bucks plus a $30 core fee at autozone than you get the $30 back when you bring them your old one. Or you can just pick up a CV Quick Boot Kit for $20 and just repair the boot. But that is your call.
before u do anything and pay, just take it apart and see if it is properly aligned. if it is and it still makes that noise, then get it fixed. because i had this sound when turning and going over bumps, but after i properly aligned it, the sound went away
