What is a good fuel injector cleaner?
Old 02-07-2009, 05:51 PM
krisfnbs's Avatar
Default What is a good fuel injector cleaner?
Whats a crappy cleaner, okay cleaner, and great cleaner? Im assuming their are alot of difference between the cheap brands, and good brands? im clueless.
Old 02-07-2009, 05:59 PM
batallic's Avatar
Default Re: What is a good fuel injector cleaner?
lucas
Old 02-07-2009, 06:01 PM
SiYouLater's Avatar
Techron
Old 02-07-2009, 06:07 PM
krisfnbs's Avatar
what about this: http://www.bgprod.com/products/fuelair.html
Old 02-07-2009, 06:14 PM
SiYouLater's Avatar
Originally Posted by krisfnbs
You can use Seafoam instead of that.
Old 02-07-2009, 06:30 PM
krisfnbs's Avatar
I have seen horror stories with seafoam.
Old 02-07-2009, 08:18 PM
iliv2xlr8's Avatar
Lucas is good.
Honestly, you aren't going to see great results from an additive cleaner. They will all be relatively the same. I would recommend having them laser cleaned by a company like RC Engineering.
Though I realize this may not be practical if it is your daily driver, or your car isn't really modified, but ultimately this is the best method.
Old 02-07-2009, 08:24 PM
SOHC_4dr's Avatar
honda doesnt like you running any cleaners or doin flushes. if you use the cleaner it'll also clean the tank, lines, and brake down **** in the filter. but remember if you do this think where all that **** is goin to. the filter could possibly get plugged and plug the injectors as well. if you do this you should replace the fuel filter after you run the cleaner
Old 02-07-2009, 09:40 PM
Unseen Racer's Avatar
^^^^^^ not always true. some brands(mainly OLD brands) use harsh chemicals that do not like parts like rubber and plastic. which lead to them being eaten away from the chemicals. now the cleaners for the fuel system are safe on any plastic and rubber parts.
Old 02-07-2009, 09:47 PM
trustdestruction's Avatar
Lucas FTMFW
/thread
Old 02-07-2009, 09:50 PM
wtf is ftmfw?
Old 02-07-2009, 09:52 PM
Originally Posted by Unseen Racer
wtf is ftmfw?
for-the-mother-f*cking-win
Old 02-07-2009, 09:54 PM
hahahahahahaha!
Old 02-07-2009, 10:07 PM
Vietnamese!
ALLxMOTOR EG's Avatar
STP is good.
Old 02-08-2009, 06:20 AM
krisfnbs's Avatar
I know that getting my fuel injectors taken out and cleaned has to be the best method to go, but fvck. Why cant things be so easy and just drop some cleaner in the bitch?
I dont really have any signs of dirty injectors, I just like to keep the car as maintained as I possibly can without going overboard. It has 96k original and I have dont pretty much all of the normal maintenance to the car. What do shops normally charge to clean injectors? Doesnt seem like it would take very long.
Old 02-08-2009, 06:33 AM
lileghatch's Avatar
alright to do a good good just take out the fuel injectors and spray some b-12 ans a old toothbrush and scrub the dam things and if you wanna clean them thru fuel cleaner use some ****..lol nah but seriously use stp it will do the job
Old 02-08-2009, 06:36 AM
lcsej1's Avatar
Techron does the job. not much to it. Fuel system cleaners are detergents. You deffinetly don't want be doing it always. I do it every 6k miles! never had any problems, but whenever i do it i also replace the fuel filter!
Old 02-08-2009, 06:54 AM
acidburn2k2's Avatar
not many people know about it but I use a kit from ever-wear. It comes as a 3-step kit.
It comes with a fuel tank additive, intake mani cleaner and an injector service. You start with adding the fuel addative int eh fuel tank. Then take the intake mani cleaner and clean you throttle body, intake mani, whatever you gan get to with a bursh. After that is done, hook up your vacuum system (like you would when doing a seafoam treatment) and fire up the car (it will hesitate to fire due to the intake mani cleaner u just used) and run the injector cleaning part through the motor (while you running this cleaner the fuel additive is runnign through the system since you put that in ahead of time)
this system is all I use and it has worked wonders for my car and my buddies' cars.
just google "ever-wear" or "qmi" it is a lakeland, FL based company
Old 02-08-2009, 01:16 PM
kw8z3boi's Avatar
I say LUCAS or TECHRON. Seafoam can do a lot of damage, I heard stories about how it mess up the gasket
Old 02-08-2009, 01:46 PM
honda.lioness's Avatar
I have been using Chevron Techron about once a year now for several years. I used STP exactly once during this time, and my PCV valve fouled somewhat. I do not get any fouling with the Techron. Not sure if the fouling definitely correlates, but I am sticking with the Techron.
SPORT INJECTION
09-19-2011 05:58 PM
gospeedgo1
08-22-2005 07:47 PM
payneth
01-07-2004 01:00 PM
G2_Integ
08-27-2001 10:16 PM
Quick Reply: What is a good fuel injector cleaner?
