leaking oil out of oil sending unit!
Old 02-05-2009, 03:15 PM
dirk digler's Avatar
Icon6 leaking oil out of oil sending unit!
so should i use some type of thread seal to stop leak?
Old 02-05-2009, 03:30 PM
P_Adams's Avatar
Default Re: leaking oil out of oil sending unit!
No. replace the sender.
If you want to; use some teflon tape on the threads, but the sender is your problem
P
Old 02-08-2009, 07:55 AM
Bad_dude's Avatar
P
Any instructions or pics to do this? The manual I got is so vague and not include this procedure in it.
Thanks.
Old 02-08-2009, 10:56 AM
hondamark35's Avatar
it's very easy once you find a socket to fit the sending unit.
pull the lead wire off, (it can be stubborn so don't give up too soon.) unscrew the sending unit and replace with the new one...
i like to use gray RTV on the threads, but PTFE (teflon) tape will work, the threads are tapered pipe threads-just FYI.
this is easiest to do durring an oil change while the filter is off so that you have easy access.
Old 02-08-2009, 11:01 AM
P_Adams's Avatar
Thanks.
Get a new Oil Filter
Remove old Oil Filter to gain access and room to move.
3/8" drive 6 point 22mm deep Socket or specialty Oil Sender Socket
3/8" Drive Ratchet. 6 or 9" handle
Disconnect wiring harness
Remove Leaking Oil Pressure Sender Unit
Reverse proceedure
Congratulate yourself
P
Old 02-08-2009, 11:34 PM
Bad_dude's Avatar
It properly sound easier if you guys do it. I am still chicken to adjust my valves.
Old 02-18-2009, 07:52 PM
Bad_dude's Avatar
What does the oil sending unit looks like?
Thanks.
Old 02-18-2009, 08:10 PM
redbull-1's Avatar
Thanks.
Old 02-19-2009, 10:42 AM
Bad_dude's Avatar
So it's a switch rather and right above where the oil filter is plug in.
Thanks for the pic.
Old 03-01-2009, 06:17 AM
Bad_dude's Avatar
Reverse proceedure
P
Hi,
Will the oil pour out when removing the send unit? Do I need to do the oil change after that? So teflon is good enough or does it have to be Hondabond type? Where can I get the oil send special socket? What so special about the socket? Is it b/c it has that center slit on the side for the lead?
Thanks.
Old 03-01-2009, 12:53 PM
journeyforce's Avatar
I would say that a small bit would come leaking out but no flood like pouring out of oil as if you opened the drain plug.
If you are near enough to a oil change then do so, if not simply top the oil off
The parts store should have a socket for the sending unit but i would think simply using a deep socket would work the same way.
I have not done much work on Honda's but I have worked a lot on GM and Ford engines and every oil sending unit I have replaced the original (factory installed one) came with red thread lock on the sending units threads. I don't know if on Honda's you can do this or not
Good luck
L
Old 03-01-2009, 04:42 PM
Bad_dude's Avatar
I have found the special socket for $3.99 plus 20% off. Guess what? I found it at the store I work at HarborFreight Tools. The item number is 95046. The problem is that, now there's no more leak from my car and I have been driven it all day today. No leak either after or during park. I guess, it's like last time when I change the gasket in my distributor. The leak is probably from the cleaning I did after changing the valve cover gasket. It's been pooling and finally comes down from the engine heat. Never the less, no oil loss at I have been checking and no more drips. I'll be watching it for the next few months.
Here's the link: http://www.harborfreight.com/cpi/cta...emnumber=95046
Is that the one I can use?
Thanks,
toyonda
01-28-2009 05:45 PM
MarcosMarcusM
01-24-2009 10:14 AM
oneludesol
01-20-2009 07:36 PM
kvkevin09
01-04-2009 02:06 PM
HX_Guy
01-08-2002 09:24 AM
Quick Reply: leaking oil out of oil sending unit!
