| Welcome to Honda-Tech! | ||
#1 |
hi i got own a 2005 honda accord 4dr lx automatic. i live in the northeast and the winter weather here sucks really bad.. well i got a cel on today as i was driving into work. later on today i pulled the car in.. and pulled the code i got a code of p2185
looked it up and p2185 is engine coolant temperature high circuit. check the connector and sensor itself no corrision or moisture however sprayed it with brake cleaner anywho. now i measure the reference voltage at the connector and i got 5v which is good so i know i have a good circuit now i measure the resistance of the sensor the car was about almost fully warmed up the resistance of the sensor is 4.013 kilo ohms.. i dont know where i can find specs of the sensor to see if its bad or good.. so far i know it has a good circuit and im getting power from the ecm. anyone care to help? anyone think the resistance is way out of spec? when the code say high circuit as in 5v still there and not being used up right help me out? if it is sensor how hard is it to change this sucker out i know i have to drain the coolant but whatelse?
Vouches : Frank_2.0L |
#2 |
I looked at the troubleshooting on isis and couldnt find a spec for you. Since you prob don't have an hds I would check continuity from the connector to the ecm. Basically boils down to a wiring problem, bad sensor or pcm needs updating or replacing(doubtful) I cant imagine the sensor would be that much and install isnt that big of a deal.
#3 |
now what is the procedure on checking continuity i was going to go ahead and replace the sensor and add new coolant fluid for the hell of it not that big of a deal..
but i can do the continuity check.. tell me which pins to check and wouldnt i need a long jumper wire to reach the connector at the radiator.
#4 |
2005 ACCORD - DTC Troubleshooting: 2005 ACCORD - DTC Troubleshooting: P2185
DTC P2185: ECT Sensor 2 Circuit High Voltage ('05-07 models) NOTE: Before you troubleshoot, record all freeze data and any on-board snapshot, and review the general troubleshooting information.
My signature |
#5 |
nevermind the mil went out i sprayed the connectors and sensor with it due to the colder weather, snow and moisture. all is okay.. thanks my honda guys lol
#6 |
i guess it was stored in history codes and the light comes on and off so im going to replace it.. how much is the sensor and what gasket or seal do i need to purchase any tips on doing this job thanks
| Tags |
| 2000, accord, acura, bb, circuit, coolant, ecmpcm, ect, engine, high, honda, idle, learn, p2185, procedure, rsx, sensor, temperature, tl, voltage |
