Old 02-01-2009, 05:00 PM   #1
Dark_Templar
Dark_Templar's Avatar
Send a message via AIM to Dark_Templar
Default Leaking brake fluid =[
So just the other day i was driving and all of a sudden my brake light went off but my E-Brake wasnt deployed and i could feel my brake gradually start sinking and i checked my brake fluid and it was almost all empty, so i added more and bled my brake lines and it worked for about 5 hours and the light went off again.
It kept going on and off for about 10 minutes then went completly solid.
Check my lines and they werent leaking.
any ideas on what i can do stop the leaking?
It might be my master cylinder im thinking?
Dark_Templar is offline   Reply With Quote
Old 02-01-2009, 05:17 PM   #2
P_Adams
P_Adams's Avatar
Default Re: Leaking brake fluid =[
I would check the entire system for leaks but 18 of 20 times it's the Brake Master Cylinder. It corrodes from the inside from water ladened brake fluid and renders the machined piston bore useless. It will require replacement if everything else checks out.
P
#1 '97 CD7 SE Accord Coupe San Marino Red / #2 '96 CD7 LX Accord Coupe Arctic White / #3 '96 EJ8 EX Civic Coupe Black / #4 '88 LXi Coupe (spare)
One more "What's the Top Speed..." thread and I think I'll flame someone
P_Adams is offline   Reply With Quote
Old 02-01-2009, 05:42 PM   #3
Dark_Templar
P
thanks for the reply.
Have any idea how much for the master cylinder on a 99 accord J30A1?
Old 02-01-2009, 06:54 PM   #4
P_Adams
P_Adams's Avatar
TAS Automotive
http://www.tasauto.com/Product/Browse.aspx?d=1100&p=1
$109.00 Genuine Honda OEM V6
Parts Geek (Adler)
http://www.partsgeek.com/catalog/1999/honda/accord/brake/brake_master_cylinder.html
$99.00 Aftermarket
Saccucci Honda
http://www.hondapartsdeals.com/hpa_parts_list.php?vin=&Label%5BProductID%5D=ACCOR D&Label%5BYearID%5D=1999&Label%5BDoorID%5D=4&Label %5BGradeID%5D=LXV6&Label%5BAreaID%5D=KA&Label%5BTr ansmissionID%5D=4AT&Label%5BSectionID%5D=CHASSIS&L abel%5BIllustrationGroupID%5D=MASTER+POWER+%281%29 &ProductID=5&YearID=17&DoorID=4&GradeID=48&AreaID= 2&TransmissionID=5&SectionID=6&IllustrationGroupID =3278
$104.00 Genuine Honda OEM
P
Old 02-04-2009, 05:30 AM   #5
lunarone
lunarone's Avatar
Send a message via AIM to lunarone
P
To inquiry on what P said ---
Does that lead to the leak that is seen when brake fluid is in between the booster and master cylinder?
lunarone is offline   Reply With Quote
Old 02-04-2009, 06:00 AM   #6
dleccord
dleccord's Avatar
Don't buy the master cylinders from Autozone.
I've replaced 3 within a year from them for my '92 Mustang.
Don't get the refurbished ones.
dleccord is offline   Reply With Quote
Old 02-04-2009, 06:28 AM   #7
TheMuffinMan
He knows where you live!
TheMuffinMan's Avatar
iTrader Rating: (1)
^ Lifetime warranty + half the cost + rebuilt OEM Nissin?
I'll take it
2004 NFR S2000
Originally Posted by slomofo
I think TheMuffinMan is Chuck Norris. Seriously, you can't find the TheMuffinMan,TheMuffinMan finds you.
TheMuffinMan is offline   Reply With Quote
Old 02-04-2009, 08:03 AM   #8
dleccord
dleccord's Avatar
^I'll take you home tonight.
2004 Honda Accord 2.4L EX
1996 Honda Accord 2.2L LX
Old 02-04-2009, 10:38 AM   #9
P_Adams
P_Adams's Avatar
Short answer: YES
The fluid is making it's way past the Piston / Cylinder Bore seal and making it's way out past the Pushrod Seal.
In really bad cases, the Brake Fluid sometimes makes it's way into the brake booster; attacking the Vacuum Diaphram.
P
1990, 1996, 96, accord, booster, brake, break, cylinder, fluid, honda, leak, leaking, losing, master, s2000
