Water/coolant leak at pipe+pump ??? Help please
Old 01-26-2009, 02:50 PM
krysted9354's Avatar
Icon3 Water/coolant leak at pipe+pump ??? Help please
ok i just rebuild my sohc went to put coolant in and noticed there coolant leaking right at were the coolant pipe and water pump meets ? { u know were the long metal pipe goes into block}
any ideas ? anybody had this happen before ?
Old 01-26-2009, 03:09 PM
Default Re: Water/coolant leak at pipe+pump ??? Help please
it leaks right on the back side of the waterpump and water pipe meets ??? d16a6 block
Old 01-26-2009, 03:10 PM
a1320addict's Avatar
Replace the waterpipe o-rings.
Old 01-26-2009, 03:11 PM
Search-first's Avatar
Get a new O-ring that goes from the pump onto the water tube from honda, cant cost more than a few dollars.
Old 01-26-2009, 03:13 PM
im 99% sure when i installed it i replaced that, so thats the only thing that can make it leak there right ?
Old 01-26-2009, 03:16 PM
unless you pinched the O-ring that goes around the water pump where it meets the block, that is the only thing that could make it leak.
Old 01-27-2009, 12:48 PM
bump
Old 01-27-2009, 01:08 PM
D50boy's Avatar
What they said. Fix that o-ring.
Old 01-27-2009, 03:34 PM
astro98's Avatar
Make sure that the pipe doesn't have a crack it it beneath the o'ring. I've had this happen before. Also I have had to replace several of these pipes on different hondas because the acidic antifreeze ate the lip of the pipe off and it continues to leak antifreeze, Honda keeps these in stock because of this problem.
Yao Saechao
03-26-2018 01:25 AM
Ainsworth03
Honda Civic (2006 - 2015)
06-27-2014 12:56 AM
highwhey
12-27-2013 05:09 AM
JuneBugDrfter
02-05-2013 08:57 PM
accord1986
01-27-2013 03:01 AM
Quick Reply: Water/coolant leak at pipe+pump ??? Help please
