Go Back   Honda-Tech > Honda and Acura Technical Forums > Forced Induction
Old 01-26-2009, 11:57 AM   #1
sonne_side
Default crower 404's good for turbo?
i have an ls turbo stock internals and was plannin on gettin the crower valve train but not sure which cams any suggestions
sonne_side is offline   Reply With Quote
Old 01-26-2009, 03:40 PM   #2
racebum
2002 Chevrolet Corvette
racebum's Avatar
Racebum
Send a message via AIM to racebum Send a message via Yahoo to racebum
Default Re: crower 404's good for turbo?
smaller cams generally work better with turbo cars. 404s are NA high compression cams. call dave down at crower and have a talk with him & explain your goals. while cams are helpful on a turbo car, the tune and properly installing the turbo kit are your first priorities.
Mountain View Carpet Cleaning also found at carpet cleaning beaverton Do you own a turbo honda? see turboinstall.net
racebum is offline   Reply With Quote
Old 01-26-2009, 07:11 PM   #3
AMLS4dr200whp
AMLS4dr200whp's Avatar
Send a message via AIM to AMLS4dr200whp
bigs cams help ls turbo setup I would recommend jg303s see my sig. JG 303s got better low end than 404s
DB squad #88
Before: Turbo LS on stock bottom end dyno: 325whp and 265ft/lbs tq neptune tuned
Now: New built LS 415whp and 331 tq s300 tuned
AMLS4dr200whp is offline   Reply With Quote
Old 01-26-2009, 10:25 PM   #4
Glove
Glove's Avatar
i think the highest horsepower LS guy used 404's on his setup.
I just bought a set and im gonna put them in a couple weeks to see how they perform.
Il post a thread on them once im done.
Glove is offline   Reply With Quote
Old 01-26-2009, 10:40 PM   #5
92civiceg9gsr
92civiceg9gsr's Avatar
ross.banner1 SuperSport01
Yeah their prolly not as good as turbo specific cams but an LS needs help breathing so they'll perform better than stock cams. Not to mention that 404's sound great.
92 EG8. GoldenEagle 84mm Sleeved GSR. BrianCrower. CP. Skunk2. ATI. Kteller. PLM. BRFittings. Endyn. MFactory. Synchrotech. SpeedFactory. CompetitionClutch. DriveShaftShop. FastBrakes. Kiwi Signature. Spoon Sports. Function7. ASR. 949Racing. PWJDM. RLZ. BRMS.
92civiceg9gsr is offline   Reply With Quote
Old 01-27-2009, 05:28 AM   #6
Wopsicle69
Wopsicle69's Avatar
I have 404's in my turbo LS, theyre absolutely SICKKKKKKK!!!!!!! Never tried anyone elses cams but the 404's work!!! I made 370 whp on 14psi on a t3/t67 and then cracked the stock piston ringlands. The block was bone stock as well. Wouldnt have an LS any other way!!!!! And the idle is dangerous http://ca.youtube.com/watch?v=1qDj3OLz4K0
1990 EF9 ....... 1.8L Roller Rocker LS/Vtec ....... S372 ....... Synchro Shifted 4 Speed ........ 9.68 @ 157mph
Wopsicle69 is offline   Reply With Quote
Old 01-27-2009, 10:32 AM   #7
Glove
Glove's Avatar
jesus, you need to get that idle tuned properly
Old 01-27-2009, 01:52 PM   #8
HiProfile
HiProfile's Avatar
Big cams with tons of overlap will do that, no matter who tunes it. They aren't like vtec cams, where the lowcam has much less overlap. Look into 'vtec killers' and other cars w/o any sort of timing advance system, they lope just the same at idle.
94 Del Sol (F2B F22), 95 Civic EX (turbo D16Z6), 94 Integra LS (H2B H23A)
try www.InjectorNation.com for 400cc-1000cc injectors
HiProfile is offline   Reply With Quote
Old 01-27-2009, 03:11 PM   #9
quicksilver1689
i ♥ snails
quicksilver1689's Avatar
Send a message via AIM to quicksilver1689
with cam gears you can give the motor what it wants depending on your turbo/manifold setup/EMP
it was a fuel used 10 years ago for go kart engines and quite illegally used into rally and drag racing. No longer exist at today.
quicksilver1689 is offline   Reply With Quote
Old 01-27-2009, 05:45 PM   #10
Glove
Glove's Avatar
thats what i mean.
reduce overlap, increase idle rpm.
would be much smoother.
he's idling at 600 it looks like.
Old 01-27-2009, 06:30 PM   #11
nonvtecallmotor
nonvtecallmotor's Avatar
rick_everley
I ran the 404's in my car as a daily driver. It idled near stock and made ~400whp on pump gas at like 15psi. Its all about the tune when making the car idle. My car went 11.5's on a 1.8 LS/ 404's on a 225 BFG a few years ago.
Washed up SFWD racer
**MobTown Racing**
http://Specclutch.com http://www.full-race.com/ http://www.turbodriven.com/
nonvtecallmotor is offline   Reply With Quote
Old 01-28-2009, 07:50 PM   #12
Glove
Glove's Avatar
do you know what you had your cam gear settings at?
Old 01-29-2009, 01:42 PM   #13
nonvtecallmotor
rick_everley
I tuned them on the dyno and no I dont remember or recommend using anyones settings. This was a set up that I had years ago.
**MobTown Racing**
Old 01-29-2009, 06:19 PM   #14
alpha
alpha's Avatar
Send a message via AIM to alpha
I've done a few cars with 404's. They've worked great on every setup. I had a car with Crower 402-T making horrible power. Only thing I could think of was the cams. So he switched to 404's. Only thing that changed was dyno'd on different days. Same dyno, same correction, etc. With the 402-T cams the car made 450whp. With the 404 cams the car made 529whp with less boost. I had the dyno sheet posted a while back but had taken it down. I will see if I can dig it up
alpha is offline   Reply With Quote
Old 01-29-2009, 07:08 PM   #15
alpha
alpha's Avatar
After a lot of searching I found it. Runs were about two weeks apart. Same gear, same start rpm, etc.
Old 02-04-2009, 08:25 PM   #16
iNERtIA
iNERtIA's Avatar
u guys know how 402T and 403 idles?
1999 B18C EK
Peakboost Turbo
11.8@118mph
iNERtIA is offline   Reply With Quote
Old 02-04-2009, 08:35 PM   #17
dephtone
dephtone's Avatar
Send a message via AIM to dephtone
I used to have Crower 62403's in my boosted b20 setup..Worked out VERY well, never got numbers but helped my b20 breathe up top where it usually lacks. I loved using them with my boosted setup. My 403s idled ~700 would drop down a little but not much.
dephtone is offline   Reply With Quote
303s, 402t, 403, 404, 404s, b20, cams, crower, dyno, gear, jg, ls, settings, spec, turbo
