Go Back   Honda-Tech > Honda and Acura Model-Specific Technical Forums > Honda CRX / EF Civic (1988-1991)
Old 01-20-2009, 10:32 AM   #1
ShayMK
Default 89 Honda CRX MAP Sensor...HELP PLEASE!
Alright I'll get straight to the point...
I just installed a TD04H turbo on my Honda CRX which I am only running 3 pounds of boost atm and I have a ECU error code (3) which is the MAP sensor. I'm just wondering, do I have to get a new MAP sensor and if so what should I look for?
Also another question, I have a 93 Honda Civic parts car which had the exact same turbo kit on it, and it has a MAP sensor on the motor...will that MAP sensor work? Or is there a specific one I have to get for a Honda CRX?
ShayMK is offline   Reply With Quote
Old 01-20-2009, 10:46 AM   #2
DTA-Zombie
DTA-Zombie's Avatar
Send a message via AIM to DTA-Zombie
Default Re: 89 Honda CRX MAP Sensor...HELP PLEASE!
no they are different
DTA-Zombie is offline   Reply With Quote
Old 01-20-2009, 11:03 AM   #3
h224thgensedan
1989 Honda Civic
h224thgensedan's Avatar
Send a message via AIM to h224thgensedan
One thing with hondas is they were not factory turbo cars. There maps, pcv, ... were not designed for boost. Are you obd 0 or obd1. Also what motor.
Originally Posted by N3va3vaSatisfi3d View Post
LOL my answer was 100% correct. I don't deal with LS garbage so I didn't know what the bore size was. I would love to see you put a B16 piston in a B18C of any kind. Pull your head out of your ***.
h224thgensedan is offline   Reply With Quote
Old 01-20-2009, 11:14 AM   #4
Clipsed
Clipsed's Avatar
iTrader Rating: (2)
Send a message via AIM to Clipsed
92+ got the maps on the TB.
4th Gen Sedan Enthusiast Group On FB!
My 4dr Build!My FS Thread!
Vouches:JDMKAY,Mashi2Choco,idh!,lunalink,KINGVEM^^ ED6
Clipsed is offline   Reply With Quote
Old 01-20-2009, 11:49 AM   #5
ShayMK
Yeah that's right haha, I didn't think it would work. But yeah I have a D16 motor and I believe it is obd0
Old 01-20-2009, 11:51 AM   #6
4drEF
4drEF's Avatar
How many psi are you boosting?
Did you add check valves on the vacuum line going to the map sensor?
Is your ECU chipped with a turbo program?
The stock MAP is -CAPABLE- of reading 9~11psi boost. The problem is that the stock ECU doesn't understand when the MAP sends boost info so it throws a code.
Adding in-line vacuum check valves hides the boost from the MAP and you won't get an ECU light/code. you then need to adjust fuel for the boost by using an FMU.
A chipped ECU with a turbo program on it is far better as it allows the ECU to use the boost information from the MAP sensor and then make fuel adjustments.
All of my posts should be considered for being made into a sticky.
4drEF is online now   Reply With Quote
Old 01-20-2009, 11:59 AM   #7
ShayMK
No I didn't add a check valve, I'm thinking of ordering one right now. I am only running 4 PSI for now until I do a few extra things. Also, I do not have my ECU chipped. Also, what ratio FMU should I use?
1990, 1991, 89, b16, check, civic, crx, honda, locate, location, map, sensor, turbo, vacuum, valve
