TPS sensor volt test
Old 01-16-2009, 10:59 PM
dohcem1's Avatar
Default TPS sensor volt test
How exactly do you test for the volt on the tps? does the car has to be on ? i dont exactly get where on the sensor can you test for the volt? thanks.
Old 01-18-2009, 12:14 AM
dohcem1's Avatar
Default Re: TPS sensor volt test
please advise?
Old 01-20-2009, 01:05 PM
chicows18's Avatar
i believe its the red wire that goes to the TPS. Car does not have to be on but ignition does. And I believe it should read as close to 0.5 v as possible. If its over, it bad.
Old 01-20-2009, 08:05 PM
dohcem1's Avatar
Well yeh I know about the .5 v and stuff I just meant how do I physically test for it. SO i basically have to strip the red wire that goes to the TPS sensor and put a multimeter and read the voltage?
Old 02-02-2009, 11:55 PM
SINISTR's Avatar
do you have a multimeter?
Old 02-03-2009, 01:25 PM
dohcem1's Avatar
yes i do, I just don't know where I could physically test the volt...
Old 02-03-2009, 05:45 PM
LA_HONDAS's Avatar
stick it in the seals
Old 02-03-2009, 10:02 PM
dohcem1's Avatar
...seals? can you clarify that? Sorry for being such a newb but i really do not know. Thanks
Old 02-03-2009, 11:42 PM
NUISANCE's Avatar
Here dude
http://www.clubintegra.com/board/showthread.php?t=21792
Old 02-04-2009, 07:55 AM
dohcem1's Avatar
Wow PERFECT PERFECT thank you for the link. Exactly what I was looking for. One last question, the OP of that thread saids to set it at .5 volt (and so did chicows18 earlier post), but i thought I saw somewhere that saids set to .45 volts is best? well does it even make a difference? Just curious. Thanks
Old 02-05-2009, 03:31 AM
NUISANCE's Avatar
I set it at .5, not sure if it makes a difference but seems to be what it is supposed to be at.
Old 02-05-2009, 10:29 PM
dohcem1's Avatar
ok thanks
Old 01-22-2010, 01:11 PM
SniperRCivic's Avatar
in my haynes book it says with the engine off and the throttle valve fully closed it should read 0.5 and with the throttle fully opened it should read 4.5
jerryliedtke
09-21-2014 09:25 AM
chrisfromsrq
08-04-2009 04:55 PM
MJT805
06-12-2009 11:05 AM
mickey513
04-16-2003 05:35 AM
Bo0sT_JuNkY
03-01-2003 07:49 PM
Quick Reply: TPS sensor volt test
