How do you clean/flush out a radiator?
So I bought a front end wrecked 95 ex coupe for 500 bucks the other week and the rad support is slightly bent but caused a leak in the radiator. My friend gave me one out of his parts civic and it is pretty grimy on the inside. What is there to use to run through the rad to clean it out?
Re: How do you clean/flush out a radiator?
if its out i suppose you could just run a garden hose throught it and maybe mix some cleaner in it, i dont know if i would install it in the car and do a normal flush if its grimy inside....getting that in the heater core would not be good, or motor
Prestone Radiator Flush. Works great!
Essentially you:
- drain the radiator
- fill with water and Prestone Radiator Flush
- drive car for 30 minutes
- drain and watch all the crap come out
- put garden hose to radiator cap and turn on water
- start car
- water is cycled through system as it drains
- watch more crap come out
- cycle until water is clear
- drain completely
- refill with proper mixture of Antifreeze and Distilled water.
I have used this product many times. You will be amazed of both how much crap is in your cooling system, and how much more efficient it becomes. I also recommend Redline Water Wetter.
-XLR8
Essentially you:
- start car
- drain completely
-XLR8
I read the post too fast...LOL
-Flush with hot water
-Make sure all the chunks are removed
-Install
-Continue with above instructions
Whatever cleaner is going to need to be pressurized to do any real good. I also wouldn't recommend any degreaser or common cleaner. These products can leave a residue behind that can react with the antifreeze, or even engine gasket corrosion.
If it looks too corroded then I wouldn't install it, buy new from: www.rockauto.com
Great prices! You can buy new and have it shipped for much cheaper than any local parts store..... guaranteed.
-XLR8
stick a garden hose in the top and seal in it (duct tape) and make a nozel (more duct tape?) so it can build a little pressure to break things loose and just let it rip is all i can think of
Essentially you:
- start car
- drain completely
-XLR8
Essentially you:
- start car
- drain completely
-XLR8
So simple green or any other degreaser isnt a good idea then to clean it out (keep in mind the radiator is not connected to the car)
No, I wouldn't use a degreaser in there. I would run the hose through it for a while and flush out what you can, then when you install it onto the car flush it out the proper way.
fill the radiator up with water, leave the water in there for a day or two to break down the gunk in there. Water is a good solvent but it takes time. I would then mix simple green and water and let it sit in the radiator for an hour or two and then run a garden hose through it for a while to make sure the radiator is simple green free.
Don't let the water sit in there, especially if it's 28 degrees outside. You may not like the results. lol
-XLR8
justinwebb
23
05-06-2009 08:24 PM
