Go Back   Honda-Tech > Honda and Acura Model-Specific Technical Forums > Honda Civic (2006 - Current)
Old 01-12-2009, 03:57 PM   #1
Boston
Boston's Avatar
Default Windshield Washer Fluid Doesn't Come out in Cold Weather
I have an '09 Civic EX. When I leave my car parked outside for multiple hours when it is below 10 degrees, the windshield washer nozzles won't spray. I usually park my car in heated garages (both at home and at work) so this problem hasn't happened to me very often. When I pull the lever, I can hear the motor whizzing but nothing comes out the nozzles. The first time I encountered the problem I figured that the windshield fluid that came with the car was low quality. I let the car warm up in my garage overnight and I siphoned out the fluid. I added new windshield fluid that was rated to -40. However, the next time I left my car parked outside in cold weather the same problem happened. Letting the car heat up and even driving it for an hour doesn't solve the problem. The only solution is to park the car in a garage for 4-8 hours. What could be wrong?
Boston is offline   Reply With Quote
Old 01-12-2009, 04:32 PM   #2
FijiBlueFG2
You mad bro?
2008 Honda Civic
FijiBlueFG2's Avatar
Default Re: Windshield Washer Fluid Doesn't Come out in Cold Weather
It's frozen. Pour hot water on where it comes out.
72 virgins can never stop a war, but 100,000 hookers can beat the Marine Corps.
FijiBlueFG2 is offline   Reply With Quote
Old 01-12-2009, 04:37 PM   #3
ef1.8
ef1.8's Avatar
My daily sleeps outside. It gets to be 30's sometimes high 20's.
Ive just gathered the nozzles freeze up since its freezingass cold outside.
Sometimes its just one, sometimes both.
Unless your using that fluid honda recalled a while back that was clogging nozzles.
ef1.8 is offline   Reply With Quote
Old 01-12-2009, 06:20 PM   #4
Boston
Boston's Avatar
So you are saying this is normal on Hondas? I never once had frozen nozzles on either of the two previous vehicles I've owned here (a super old Mazda and a VW).
When this problems happens to me, I usually don't have access to hot water right away. I can park in garages most of the time so it doesn't happen when I'm at home or work. It only happens when I'm out - shopping, dining, etc. It's not very convenient to go up to the bartender or salesclerk and ask for hot water because my washer nozzles have frozen.
According to owners link, there are no recalls on my car. Yet. I can't find much info about a Honda recall of washer fluid. ADD: And the problem only occurs when the car is parked outside for awhile in cold temps.
So is there nothing else I can do? In my area the winters are COLD and with all the snow, salt, de-icer, and other muck on the road I really, really need to be able to use washer fluid.
ADD: I'd also like to add that there isn't any snow or ice obstructing the nozzle openings.
Old 01-12-2009, 08:34 PM   #5
FijiBlueFG2
You mad bro?
2008 Honda Civic
Take your bare hand and place it over the nozzle for a minute or two. Might do the trick.
Old 01-13-2009, 07:56 AM   #6
Boston
Boston's Avatar
I called the dealership where I purchased the car. They informed me that because of the placement of the washer reservoir and the lines, they are very susceptible to freezing in temps below or around zero. The told me to avoid the blue gas station fluid, even if it's supposedly rated to -40. They recommended Prestone and RainX de-icer washer fluids. Anyone have a preference between the two?
Old 01-13-2009, 10:06 AM   #7
COCA GROUND ASSAULT NY
The freezing is normal on any car nit just hondas as u start driving and the engine heat , heats up the hood it will start to work..
COCA GROUND ASSAULT NY is offline   Reply With Quote
Old 01-13-2009, 11:44 AM   #8
06BlackSi #45
06BlackSi #45's Avatar
Send a message via AIM to 06BlackSi #45
Just add a bottle of 70% Isopropyl alcohol to your wash fluid, or buy the Prestone Windshield Washer Fluid that has the de-Icer in it.
Travis Stikeleather
2006 Civic Si -Daily Driver-, 1999 Civic Si -Sold-, 1994 Acura Integra -Sold-
1983 Civic 1500 4 Door -Still have, K20 project car-
06BlackSi #45 is offline   Reply With Quote
Old 01-13-2009, 12:08 PM   #9
Originally Posted by 06blacksi #45 View Post
just add a bottle of 70% isopropyl alcohol to your wash fluid, or buy the prestone windshield washer fluid that has the de-icer in it.
even if u replace wit the liquid the actual sprayers might be frozen . So it still wont come out or spray.. Thats why when u drive the engine heat will heat the sprayers up and then it will work..
Old 01-15-2009, 12:38 PM   #10
Go_Race_Your_Self
Two Piece
1993 Honda Del Sol
Go_Race_Your_Self's Avatar
NaSTeBoyiix
I <3 my DelSol
'93 Si Del Sol- Stock B16A with basic bolt ons. 154hp/109tq 93 pump
Go_Race_Your_Self is offline   Reply With Quote
Old 01-15-2009, 12:55 PM   #11
-RideEmHard-
-RideEmHard-'s Avatar
Here in Canada you can pick this baby up at a Canadian tire unsure if there is anything like it in the U.S.
empty your tank dump her in then fill the rest with washer fluid wont freeze up and melts everything it touches works like a charm.
http://www.canadiantire.ca/browse/pr...=1232056384437
^^I Write It, You Read It. Not My Problem.
'90 C[COLOR=Black]ivic[COLOR=Red][COLOR=Black]SI[/COLOR] [/COLOR]- R.I.P.
'07 [COLOR=Black]Type[/COLOR]-[/COLOR][COLOR=Black]S [/COLOR]- Current-New Play Toy
-RideEmHard- is offline   Reply With Quote
1994, accord, acura, car, civic, fill, fluid, honda, shield, spray, tl, video, washer, wind, windshield, wiper
