Old 01-05-2009, 01:31 PM   #1
85_305
85_305's Avatar
Send a message via AIM to 85_305
Default Why does my car crank and crank and crank before starting?
It must be a honda thing?? All three hondas i've owned did it.
This one, my '98 HX, on the first start of the day will crank for an obnoxiously long period of time before turning over. What gives?
Matt
Too many cars to mention. Wideband for sale.. will fit HX's! PM for more info
Originally Posted by AyeYo View Post
Of course. But, then again, the scumbags of GDD shouldn't really be a barometer of society...
85_305 is offline   Reply With Quote
Old 01-05-2009, 01:37 PM   #2
BryanM.
Resident Gearhead
2007 Honda Civic
BryanM.'s Avatar
iTrader Rating: (1)
Default Re: Why does my car crank and crank and crank before starting?
All of my Hondas start(ed) right up. Maybe it needs an ignition tune-up?
PICS: '07 FG1 - DD
......... '96 EJ6 - SOLD
......... '92 EH2 - SOLD
BryanM. is offline   Reply With Quote
Old 01-05-2009, 01:56 PM   #3
85_305
85_305's Avatar
It only seems to do this when cold? But my del sol did the same thing, and everything on that car is brand new. Though it seems like my extended cranking on the Sol is gone since I've been driving it more often?
Old 01-13-2009, 07:45 AM   #4
85_305
85_305's Avatar
It's still doing this. Could the plugs not be gapped correctly and cause this?
Old 01-13-2009, 07:51 AM   #5
accord_raffi
1999 Saab 9-3
My Garage
accord_raffi's Avatar
Send a message via AIM to accord_raffi
Is it getting fuel?
1996 Turbo Honda Accord LX *SOLD*
1999 Saab 9-3 Viggen *Current*
CD Squad Member #196
accord_raffi is offline   Reply With Quote
Old 01-13-2009, 08:05 AM   #6
85_305
85_305's Avatar
Pretty sure. It seems as though it cranks and cranks and cranks, so I stop cranking for a few seconds, try again, and either it will do the same thing or it will start up. I would think its getting fuel but dunno
Old 01-13-2009, 08:11 AM   #7
REDesignIT
Its cold outside, your battery is probably old or does not have enough "cold cranking amps" to beat the super cold weather. I bet when its warm it starts fine ????
When you crank and crank, the Alternator adds a little bit of juice to the net system, as long as your battery has a strong charge then typically you will get just enough spark to get it to fire up after a couple tries.
Upgrade your battery to more cold cranking amps and you should be fine.
REDesignIT is offline   Reply With Quote
Old 01-13-2009, 08:20 AM   #8
85_305
85_305's Avatar
I've noticed it actually does it any time it wants, the car doesn't necessarily have to be stone cold.
My buddy suggested the same thing about the battery. Even if it's cranking really fast and all that, you think it may still not have enough cca?
Old 01-13-2009, 08:31 AM   #9
Jonathan_ED3
Jonathan_ED3's Avatar
Send a message via AIM to Jonathan_ED3
Try switching your key to the "on" position and hold it for a few seconds. Then start your car. Does it crank right over? Or does it still crank and crank?
My Vouch Thread
'79 Civic w/d16z6, '83 Civic S w/d16z6, '85 RX7 w/LS1/T56, '78 Corolla w/LS1/T56, '06 TSX -stock.
Jonathan_ED3 is offline   Reply With Quote
Old 01-13-2009, 09:00 AM   #10
85_305
85_305's Avatar
I'll get back to ya on that
Old 01-13-2009, 09:13 AM   #11
accord_raffi
1999 Saab 9-3
My Garage
I don't think this is a battery related issue. If you click it into the 'on' position, can you hear the fuel pump make a whirring type of noise? If you hear it, then your fueling system should be pressurized. Otherwise, it could be something with your ignition. Do some tests for spark and check your fuel pressure if you can.
Old 01-13-2009, 09:44 AM   #12
85_305
85_305's Avatar
Doubt I can check fuel pressure, but could it be because the wrong plugs and wrong gap are in it? I haven't checked to verify yet, but I have a feeling they are messed up.
Old 01-13-2009, 05:10 PM   #13
accord_raffi
1999 Saab 9-3
My Garage
Your plug gap being off is not going to stop a car from turning on. It would just run poorly. But do what i said in the last post and listen for your fuel rail being pressurized. Try to do a spark test after and see if you're getting spark. There is a tool that checks this you can buy at an autoparts store maybe. You take out the spark plug wire and plug one end into the wire and then the other on the spark plug and it checks your spark. there is a screwdriver method as well.
Old 01-13-2009, 05:13 PM   #14
85_305
85_305's Avatar
^You probably know more about hondas than I do, BUT with my gst I used to have, if the gap was off or you weren't running the very special plugs it needed, NOTHING ran right. Hell, even the brakes didn't work with the wrong plug/gap!
I really think that if the gap is SO far out, it might have trouble igniting sometimes. So I'm gonna check it out and I'll report back my results.
I'll listen for the fuel system pressurization also.
Whats weird is, often times when I pull into my parking spot the car will just shut off and die.. and SOMETIMES at a red light it will just die. I wonder if this is all related.
Old 01-14-2009, 04:44 AM   #15
tercel95
tercel95's Avatar
My car does this it seems like randomly. Sometimes it starts right up, even in the cold and sometimes it has to crank a bunch before starting. My old roommates civic did the same thing.
tercel95 is offline   Reply With Quote
Old 01-14-2009, 04:54 AM   #16
85_305
85_305's Avatar
^You guys never figured out what the problem was? Because My del sol used to do it all the time.. and It seems like all I did to make it go away was drive it more often..
Old 01-14-2009, 06:12 AM   #17
ej8_tuner
Try to check your fuel filter..
ej8_tuner is offline   Reply With Quote
Old 01-14-2009, 06:13 AM   #18
accord_raffi
1999 Saab 9-3
My Garage
We're here to help, but we can't do that if you can't even help yourself. Have you even done what I told you to do?
Old 01-14-2009, 06:23 AM   #19
fryguy190
1992 Honda Civic
My Garage
fryguy190's Avatar
Andrewcfryer
Send a message via AIM to fryguy190 Send a message via MSN to fryguy190 Send a message via Yahoo to fryguy190
my car does the same thing. in the morning i turn my key to "on" to turn on the fuel pump. then shut it off. turn it on again and then it starts right up... in my car if it sits for a long time the fuel driains back into the tank....
Motto: stand for somthing, or live for nothing. you choose.
92 Civic Hatch CX single-jingle "for now"
fryguy190 is offline   Reply With Quote
Old 01-14-2009, 06:24 AM   #20
kuja396
kuja396's Avatar
I've owned like 6 civics and I have one now currently that does that exact same thing, I don't think its weather or battery related, I never figured out what does it!
Originally Posted by suspendedHatch
Honda-Tech is years behind the game. The people here adhere to trends, attack anything that's new or different, are closed minded and set on things that are not set in stone, they're slow to adopt new things, brand loyal and extremely biased...
kuja396 is offline   Reply With Quote
Old 01-14-2009, 06:37 AM   #21
Vindicator9000
318 Curves, 11 miles
2000 Honda Civic
Vindicator9000's Avatar
^^^This. Gotta prime the fuel pump. Every civic I've ever driven didn't like to start right away if it was below 1/4 tank of gas. They would crank 6-7 times before starting. But if I turned the key to the on position for 2-3 seconds before starting, they would all start right up, every time.
Never figured out why, but mine did it fresh from the dealer with 7000 miles on it.
Originally Posted by Arcitekt View Post
here comes vindicator with his 30 line posts.
Vindicator9000 is offline   Reply With Quote
Old 01-14-2009, 06:47 AM   #22
kuja396
kuja396's Avatar
That would be crazy if it was only that, I'll give it a try!
Old 01-14-2009, 07:01 AM   #23
Black4thgenEF
Black4thgenEF's Avatar
I always do this and my car always starts on the second crank. If I just try to start it after sitting for a couple days, it cranks a few times before starting.
Black4thgenEF is offline   Reply With Quote
Old 01-14-2009, 07:05 AM   #24
t_mac
if it gets cold like it does here then you need to get a block heater, if you already have one then plug it in for a hour or so before you try to start it up.
t_mac is offline   Reply With Quote
Old 01-14-2009, 07:45 AM   #25
Black4thgenEF
Although a block heater is a good idea in cold areas, I've never had a problem with slow starts and I suspect that it's colder here than where you are.
1994, 96, accord, car, couple, crank, cranking, cranks, fast, honda, slow, start, starting, starts, times
