> Honda Accord (1990 - 2002)
Old 01-05-2009, 08:39 AM   #1
low430
1999 Honda Accord Coupe
Default 3rd clutch pressure switch 99 accord
I called 2 honda dealerships neither one could tell me what part number I need or where its located.
99 accord 4cyl ex automatic threw a p1739 code. I want to just replace the switch. Car drives pretty normal but seems to shift slow when coming to a stop.
I have searched everywhere including google and the only thing I could find were details on the v6 auto switch location.
I know there was a recall but I dont know if the 4cyl were also included, either way Im past 116k so there is no point even saying the word recall because at this point it doesnt even matter.
Ill replace the switch and flush the tranny if it doesnt run right either 5 speed swap or f20b swap.
Can someone please point me in the right direction? If you had this same issue did replacement of the switch resolve the issue?
Thanks for your time
Just picked her up on friday.
Please take away some more of my precious user rating
low430 is offline   Reply With Quote
Old 01-05-2009, 09:02 AM   #2
P_Adams
P_Adams's Avatar
Default Re: 3rd clutch pressure switch 99 accord
As you can see from this:
http://www.hondaautomotiveparts.com/...ENSOR-SOLENOID
Honda is of absolutely no help. Even the parts nomenclatures are no help.
I'll see what I can find
P
#1 '97 CD7 SE Accord Coupe San Marino Red / #2 '96 CD7 LX Accord Coupe Arctic White / #3 '96 EJ8 EX Civic Coupe Black / #4 '88 LXi Coupe (spare)
One more "What's the Top Speed..." thread and I think I'll flame someone
P_Adams is offline   Reply With Quote
Old 01-10-2009, 08:54 AM   #3
low430
So I tried every honda dealership to No avail.
This sucks. the car drives almost normal if your soft on the gas.
I really dont want to destroy my tranny by running it with a bad pressure switch.
Plz someone can you steer me in the right direction?
Old 01-12-2009, 06:14 PM   #4
DrRuss
I saw an answer to this question from a Honda Tech (which I can't seem to find again) that said that item number 14 in the parts list above is the 3rd clutch pressure switch. This is apparently a common item to go bad on this generation of Accord.
Good luck,
Russ
DrRuss is offline   Reply With Quote
Old 01-12-2009, 06:38 PM   #5
trrbl1bmx
trrbl1bmx's Avatar
Send a message via AIM to trrbl1bmx
Hey man, I work at a Honda Dealership in Charleston,SC. The 3rd pressure switch is a common problem on these accords. I wouldn't get down in the dumps about it. These is no need to "flush" your transmission, with a pressure switch code, actually Honda doesn't recommend flushing at all, unless with their approved Honda specific machine, that only flushes the trans fluid from the radiator. Now back to your switch, the one you need to replace is in the front, closest to the radiator of the car, down on the left, right below the soleniods. It has an aluminum crush washer much like a drain plug, so make sure you reinstall it carefully an do not overtighten, the new switch should come with a new washer.
Just so you know even up to around 175k miles, Honda will offer what is called a "goodwill" on auto trannys that go out, or get torque converter code, start to slip ect.
They will pay a large portion of the bill, and you the customer end up with around $300-$500 bill out about a $3400 job. Not bad. Hope I helped you out.
RoundFAB
trrbl1bmx is offline   Reply With Quote
Old 01-16-2009, 04:49 PM   #6
low430
thanks for the info, I paid 69 dollars for the part, It fixed the upshift issue, Car drives great.
Only thing is I still get a slow downshift into first when coming to a stop.
Is there a special procedure I should go through after disconnecting the battery as to allow the ECU to adjust to everything?
Old 01-26-2009, 03:53 AM   #7
dsharrier
My engine check light came on at first the computer said it was the oxygen sensor then they deleted the code. It came on again sayin its the clutch pressure switch. I called a number of parts place and none of em sells such switch... What could be the real prob? Can someone plz help me out? Thnx in advance
dsharrier is offline   Reply With Quote
Old 08-19-2009, 05:01 AM   #8
rjp
Low430,
This is great news! I have the same code on my 1999 accord. I am trying to understand if it is a switch problem or a transmission problem. Is your transmission still working well, or did the problem eventually return?
I understand it was fixed at first, but if the problem was due to debris in the tranny clogging the passages or screens, then I assume it would return over time.
Is the part definitely #14 in the diagram in this thread? Looks like the bottom most sensor on the tranny right?
I have the 4 cyl btw.
Please forward any info you might have learned about this issue.
Thanks,
Rich
rjp is offline   Reply With Quote
Old 11-18-2010, 04:47 PM   #9
tpot90
tpot90's Avatar
Send a message via AIM to tpot90
Can I resurrect this topic? Just got the P1739 code, 3rd clutch pressure switch. The link that PAdams posted doesn't offer any diagram that I see. I have a 98 2.4L LX so I'm assuming its the same part. Can someone PLEASE help me with an exploded view or Part# for the switch? Part # would be most helpful!!
EDIT: Just found an Acura TL DIY 3rd gear pressure switch write-up. In it I found part # 28600-P7Z-003. Anyone have an Accord part #?
1998 Accord LX Coupe F23a
Sprint lowered, Moog overhaul. I/H/E
I <3 MY CG3.
tpot90 is offline   Reply With Quote
2000, 2nd, 3rd, 98, accord, clutch, crv, honda, located, location, pressure, replace, replacing, switch, switches
