Go Back   Honda-Tech > Honda and Acura Model-Specific Technical Forums > Honda Civic (2001 - 2005)
Old 01-03-2009, 11:26 PM   #1
It Wasn't Me
Icon3 ► Fuse and Relay Info
UNDER THE HOOD
A - Radiator Fan Relay
B - A/C Compressor Clutch Relay
C - Rear Window Defogger Relay
D - Blower Motor Relay
E - Headlight Relay 1*
F - Headlight Relay 2*
F - Headlight Relay**
G - Condenser Fan Relay
H - Horn Relay
*2001 model
**2002-2005 models
1 - Condenser Fan Motor (blue/yellow wire) / AC Compressor Clutch (blue/red wire)
2 - Audio Unit, Dash Lights, Front Parking Lights, Front Side Marker Lights, Heater Control Panel, License Plate Lights, Rear Side Marker Lights, Taillights.
3 - Ceiling Light, Ignition Key Light, Spotlights, Trunk Light
4 - Radiator Fan Motor
5 - Turn Signal / Hazard Relay, Turn Signal Lights
6 - CKP Sensor, ECM/PCM, Injectors, IAC Valve, Immobilizer Control Unit Receiver, PGM-FI Main Relay 1 and 2, TDC Sensor.
7 - Horn, Brake Lights (to ABS Modulator Control Unit, Cruise Control Unit, ECM/PCM, Multiplex Control Unit)
8 - ABS Modulator Unit
9 - Audio Unit, Data Link Connector, Gauge Assembly, Immobilizer Control Unit Receiver, Immobilizer Indicator Light, Keyless Receiver Unit, Multiplex Control Unit, Security Control Unit, Audio Unit.
10 - ABS Modulator Control Unit
11 - Rear Window Defogger (via antenna module)
12 - Blower Motor
13 - #7 fuse (in the under-dash fuse/relay box), Power Window Relay
14 - #3 and #16 fuses (in the under-dash fuse/relay box)
15 - Daytime Running Lights Control Unit (Canada), High Beam Indicator Light, Left Headlight. (01-03 use 15 amp / 04-05 use 20 amp)
16 - Multiplex Control Unit
17 - Daytime Running Lights Control Unit (Canada), Right Headlight (01-03 use 15 amp / 04-05 use 20 amp)
18 - Battery, Power Distribution
19 - Ignition Switch (BAT)
ALT = Alternator
BAT = Battery
ELD = Electronic Load Detector
X = Spare Fuses
UNDER THE DASH
A - Starter Cut Relay
B - Taillight Relay
C - Power Window Relay
D - Turn Signal / Hazard Light Relay
1 - Ignition Coils
2 - Air/Fuel Ratio Sensor, ECM/PCM*
3 - Daytime Running Lights Control Unit (Canada), Multiplex Control Unit
4 - Alternator, Cruise Control Unit, ELD Unit, EVAP Bypass Solenoid Valve, EVAP Canister Purge Valve, EVAP Canister Vent Shut Valve, Primary / Secondary / Third Ho2S, Vehicle Speed Sensor (AT, MT)
5 - NOT USED
6 - Moonroof Open/Close Relays, Power Window Relay
7 - Moonroof Motor
8 - Audio Unit, Multiplex Control Unit
9 - OPDS Unit
10 - Back-up Lights, Gauge Assembly, Keyless Receiver Unit, Multiplex Control Unit, Reverse Relay (AT, CVT), Security Control Unit, Shift Lock Solenoid.
11 - ABS Modulator (IG2)
12 - Daytime Running Lights Control Unit (Canada)
13 - SRS Unit
14 - A/C Compressor Fan Relay, Blower Motor Relay, Condenser Fan Relay, Heater Control Panel, Power Mirror Actuators, Radiator Fan Relay, Recirculation Control Motor, Rear Window Defogger Relay.
15 - NOT USED (Accessory Security Control Unit)
16 - NOT USED
17 - ECM/PCM, Fuel Pump, SRS Unit
18 - Accessory Power Socket
19 - Turn Signal / Hazard Lights Relay
20 - Multiplex Control Unit, Windshield Washer Motor, Windshield Wiper Motor
21 - NOT USED
22 - Passenger's Power Window Motor
23 - Driver's Power Window Motor
24 - Left Rear Power Window Motor (sedan)
25 - Right Rear Power Window Motor (sedan)
*2003-2005 models
NOTE: Images are of 2002 EX coupe fuse boxes.
It Wasn't Me is offline   Reply With Quote
02, 2001, 2002, 2003, 2004, 2005, 2006, acura, box, civic, fuse, fuses, honda, manual, owners, rsx, si
