Go Back   Honda-Tech > Honda and Acura Technical Forums > Paint and Body
Old 12-22-2008, 07:35 PM   #1
HamiltonRex
HamiltonRex's Avatar
Default Clear coat curing times?
Hi, i painted a small section of my car, the rear.
However, im concerned if the clear coat is fully cured yet, as well as the base coat. The night it was sprayed it was aprox 14 deg C above freezing.
However, after it was sprayed, it stayed at that temp for about 3 hours, than it was well below freezing for about a day, than i had it up to about 10 deg C for maybe 5 hours, and than cold for today, well ive had the stove going and its about 15deg C in there and it will be for about 8 hours total.
Does clear and base cure in sub zero temps, the extra clear i had in a jar turned solid, and i mixed everything properly. Just want to make sure im giving this enough time.
Thanks!
1g awd auto dsm
9.9 @ 139
HamiltonRex is offline   Reply With Quote
Old 12-23-2008, 02:55 AM   #2
Disease
Disease's Avatar
Send a message via AIM to Disease
Default Re: Clear coat curing times?
Touch it and find out. LOL don't do that. I would not know just could'nt resist. Should be dry to touch but still soft, my guess.
Disease is offline   Reply With Quote
Old 12-24-2008, 04:50 PM   #3
precisionsc54
It might haze over if it didnt get to fully cure through
precisionsc54 is offline   Reply With Quote
Old 12-25-2008, 12:00 PM   #4
prelude1897
prelude1897's Avatar
Send a message via AIM to prelude1897
Clear coat doesn't take too long to dry depending on how many coats you put on, and how well you mixed it. The more hardener you put in it, the quicker it'll dry, but I still don't suggest going way over the mixture ratio
97 Prelude-wrecked
00 Prelude-Daily Driver
99 Prelude-RHD Prelude http://images.honda-tech.com/set1/smile/emwink.gif
98 Prelude-Parts Car-SOLD
<FONT COLOR="blue">Retrofit service/pics</FONT>
http://www.myspace.com/bceretrofits
prelude1897 is offline   Reply With Quote
Old 12-25-2008, 04:46 PM   #5
FearTheH
1999 Honda Civic
FearTheH's Avatar
Send a message via AIM to FearTheH
Best thing to do is use the proper ratio, and if you want it to look good, spray it in a controlled environment. I always allow mine to cure for 48 hrs at 70-75 degrees F. That's more than most would do but I have never had a complaint nor had to repaint a car. But with the temperature bouncing around it can cause the clear coat to become foggy. Hope this helps man. Good luck!
Originally Posted by chelt_scene View Post
97 civic coupe.
want a duckbill spoiler for it where can i get them from?
FearTheH is offline   Reply With Quote
Old 01-22-2009, 02:11 PM   #6
HamiltonRex
clear coat cured about 3 days, at temperatures between -15 deg C and +15 deg C depending on how much wood i had in the stove, it looks fine now.
Thanks everyone.
1g awd auto dsm
9.9 @ 139
Old 02-11-2009, 10:06 AM   #7
G0TB00ST
2004 Mitsubishi Lancer Evolution
My Garage
G0TB00ST's Avatar
Location: ON A STREET NEAR YOU BREAKING TRACTION ON ALL 4 WHEELS!
Send a message via AIM to G0TB00ST
Interesting info to know!
Originally Posted by G0TB00ST
Originally Posted by alexsracing View Post
spec v drivers ESPECIALLY Bacon973 like she male **** its a scientific fact
|04 RALLY RED RS|STOCK... I SWEAR!|00 CRYSTAL WHITE GS300|WHAT INTERCOOLER?
G0TB00ST is offline   Reply With Quote
1k, 97, clear, clearcoat, coat, cure, curing, degrees, foggy, fully, hardening, humidity, long, soft, still, time
