Go Back   Honda-Tech > Honda and Acura Model-Specific Technical Forums > Honda CRX / EF Civic (1988-1991)
Old 12-22-2008, 04:35 AM   #1
st_rage
Default What did I break (frozen radiator)
So my brother borrows my civic, which had been sitting for a while. Evidently it was short on coolant, as it started to overheat on him. He fills it up with water and of course we get a 15 degree low over the weekend. Where should I be looking for problems?
st_rage is offline   Reply With Quote
Old 12-22-2008, 05:48 AM   #2
digitally_remastered
1993 Honda Civic
digitally_remastered's Avatar
Default Re: What did I break (frozen radiator)
well for starters, warm the car up for about 15-20 minutes. than take the rad out since it will still be frozen. pop the drain plug off the block and let it drain. then reinstall the plug. after that you want to take the rad inside overnight or just start running hot water through it in the tub or a basement sink. when you go to put the rad back in your going to want to fill the rad then pour some of the coolant/water mix through the heads water port to fill the block up again with coolant. more than likely if you dont do that your block will get fudged because the thermostat hasnt opened yet.
digitally_remastered is offline   Reply With Quote
Old 12-22-2008, 05:56 AM   #3
st_rage
We'll get up above freezing during the day, so I can run antifreeze through it then. I'm just curious where I should look for leaks since it was likely a block of ice overnight.
Old 12-22-2008, 06:35 AM   #4
1993 Honda Civic
leaks will be the least of your worries. i just did this though as i had left the water from summer in my motor/rad and didn't change it because i didn't plan on driving the car at all this winter. mine was frozen just like yours and i did what i told you to do and i haven't had any issues yet. once you get it all changed out and let the car get up to operating temp you should be good. you may need to add a little more rad fluid though after a decent drive. maker sure your heater core is open all the way and on full blast to get the ice in it thawed lol.
Old 12-22-2008, 08:47 AM   #5
rbwdriven
rbwdriven's Avatar
I did the same years ago on my civic.
It warped the head so bad you could see light under it when the head was sitting on a precision flat table.
it took most of the day to warm it to get all the ice out. After we looked at it we pretty much said motor swap.
eastcoastefcivics.com
madmenefparts.com
vouches:r6_rider23 (great buyer), Rjp4419 (great seller), B_Something (great seller)
rbwdriven is offline   Reply With Quote
Old 12-22-2008, 08:57 AM   #6
specialized108
specialized108's Avatar
Send a message via AIM to specialized108
do you have a heated garage you can park it in for a few hours? just let it warm up...?
specialized108 is offline   Reply With Quote
Old 12-22-2008, 11:45 AM   #7
Tyson
Tyson's Avatar
do you know for sure its frozen inside?
if there was still old coolant in there, it would have mixed with the new water and still may have been fine.
but yeah, not good to leave water in the cold weather.
Don't IM me your TECHNICAL question. Start a thread, I'll answer there.
FS: Mugen CF-48 13x5.5 -38 Wheels *NIB*
FS: 4040 Brake Proportioning Valves
Tyson is offline   Reply With Quote
Old 12-22-2008, 12:31 PM   #8
skidmarkroyalty
skidmarkroyalty's Avatar
iTrader Rating: (1)
ha! reading this just reminded me that i have water in mine too... i better get out there adn change that. even though this winter weather feels like fall weather over here in tn.
suckit inc.
skidmarkroyalty is offline   Reply With Quote
Old 12-22-2008, 07:48 PM   #9
90sedan
90sedan's Avatar
Send a message via AIM to 90sedan
Get the car into a heated garage and let it sit for a few hours/over night and once the coolant/water is no longer frozen, drain and fill with a 50/50 mix. Run the car and check for any obvious leaks or issues.
SpeedFactory Tuning and Race Fabrication
90 Ef Sedan
vitara d16
90sedan is offline   Reply With Quote
Old 12-23-2008, 01:51 PM   #10
rangerxtrn
rangerxtrn's Avatar
Send a message via AIM to rangerxtrn
drained mine at 36*F outside! thanks guys I have the typical intake tab leak on the top of my radiator, I have been putting water in it all summer, just read this and changed it before it froze, if the radiator is frozen since the tanks are plastic look at all 90* bends and brackets, those are the weak points in the plastic, also check the tubes, and lastly the waterneck, if you want to see if its frozen take the cap off and start the car, check to see if you have any circulation in the top of the rad... oh, and check for leaks at the alum./plastic joints between the tanks and the core...
rangerxtrn is offline   Reply With Quote
Old 12-25-2008, 01:09 AM   #11
zurud
zurud's Avatar
If the radiator froze, I'll imagine the engine froze too. Crack the block. Needs new engine block.
zurud is offline   Reply With Quote
Old 12-25-2008, 06:36 AM   #12
ZAKU
ZAKU's Avatar
That's not necessarily true, I'm pretty sure the frost plugs are intended to pop out before the block cracks.
ZAKU is offline   Reply With Quote
Old 12-25-2008, 09:32 AM   #13
schock3
schock3's Avatar
Send a message via AIM to schock3
bump
BUILD IT, RACE IT, BREAK IT, FIX IT, REPEAT
Originally Posted by 95tegbuild View Post
if you cant do your own work buy a stock car and keep it that way.
schock3 is offline   Reply With Quote
Old 12-25-2008, 09:56 AM   #14
acmoc
acmoc's Avatar
https://www.facebook.com/profile.php?viewas=100000686899395&privacy_source=timeline_gear_menu
your block can crack even if you don't start the car, it's the expanding of the frozen water when it thaws that will crack it.
Remove all the coolant hoses, radiator, caps, drain plugs etc., so the coolant has somewhere to expand into. That's really your only option
365
A[i]
acmoc is offline   Reply With Quote
antifreeze, break, car, cold, coolant, ep3, froze, frozen, hose, putting, radiator, remove, valves, water, weather, winter
