Rocker arm adjustment.
Old 12-18-2008, 08:28 PM
VTEC1n2nd's Avatar
Default Rocker arm adjustment.
SO my rocker arms make a ton of noise on my d16y8 when i get around 3k RPM. It gets annoying after a while. Is there any way to adjust them?
Old 12-18-2008, 09:27 PM
Jimster480's Avatar
mine just whine. But then again my motor is just beat. Which is why im swapping it out of there lol.
Old 12-18-2008, 09:42 PM
Ruben19's Avatar
this is call a valve adjustment job.
Old 12-19-2008, 05:39 AM
Jimster480's Avatar
mine needs more than that.
Old 12-19-2008, 05:55 AM
z6hatchboy's Avatar
for the op, to do a valve lash adlustment. Take the v/c off and at the end of the rocker arm will be a lock nut and lash adjuster that goes does to the valve. Loosen the lock nut with a 8 or 10mm wrench, use a feeler gauge between the valve and adjuster and adjust the aduster to spec. I think the inake is .008" and the exhaust is .012"..i tihnk but go look your up and make sure
Big red89
12-18-2007 10:44 AM
jtchinoy
06-26-2006 09:26 PM
Hawkze_2.3
07-30-2004 06:32 PM
draco067
03-11-2003 07:18 AM
Quick Reply: Rocker arm adjustment.
