>>>> ACL Race Bearings - Main, Rod, Thrust >>>>> Gates Racing Hoses and Belts !!!!!
http://www.IPGParts.com
Email -- Sales@IPGParts.com
Phone -- 407-324-4684
Payment methods:
Paypal -- Sales@IPGParts.com
Credit Card over the phone -- 407-324-4684
Wire Transfer
Mail us A Money order
ACL Race Series Performance Engine Bearings
The unique combination of design, metallurgy and engineering come together to deliver what drivers expect from high performance Trimetal engine bearings.
Designed to withstand higher RPM conditions, ACL Race Series Engine Bearings are available for many of the popular 4, 6 & 8 cylinder applications and feature:
-- High strength overlay plate with reduced thickness for improved fatigue properties
-- Hardened steel backs on all rod bearings to improve the support of the bearing lining and assist with bearing retention in the housing.
-- Increased crush for improved bearing retention
-- Elimination of flash plating on the back of the bearings to improve heat transfer through the bearing sand to maximize the grip between the bearings and its housing.
-- Increased eccentricity to compensate for bore distortion at high rpm and to assist in the formation of hydrodynamic oil films.
-- 3/4 grooved Main Bearings to optimize bearing load carrying surface area and oil flow to the conrod bearings.
-- Tight consistent wall tolerances to help you maintain consistent clearances.
-- Enlarged ID chamfers on bearing edges where required to accommodate large fillet radius on performance crankshafts.
Applicatons for ACL Race Bearings include:
Please PM, Email Sales@IPGParts.com or call 407-324-4684 for Pricing Information !!!!
Honda/Acura:
D16a1
D16a6
B17a1
B18a1
B18b1
B18c1
B18c5
B18c
B20b / B20z
D16y6 / D16y7 / D16y8 / D16z6
K20a3
K20a2
K24a
F20c
F22c
H22a4
F23a
Mazda:
B6-T
BP-T
Mitsubishi:
4G63
4G64
4G63T (1st Gen, 2nd Gen, Evo8, Evo9 )
Nissan:
SR20DE
SR20DET
RB25DETT
RB26DETT
RB30
RB30ET
VG30DE
VG30DETT
VQ35DE
CA18DE / CA18DET
Subaru:
EJ16
EJ18
EK20
EJ22
EJ25
Toyota:
4AGE
4AGZE
3SGTE
2JZGE
2JZGTE
1UZFE
2UZFE
__________________________________________________ ___________________________
Gates Racing Performance Timing Belts
Incredibly strong, extremely heat resistant. Tough enough to take the worst pummeling your engine can dish out. No other belts help protect your engine and deliver high performance like Gates Racing Performance Timing Belts.
Yes, the color gives you a hot custom look. But look deeper. Constructed of HNBR elastomeric composites, Gates Racing Performance Timing Belts are 300% stronger than stock belts and deliver up to three times the heat resistance. You can count on them to hold up to the rigors of high horsepower, even with interference engines.
-- Wear Resistant Teeth. High saturation HNBR elastomeric composites contribute to the exceptional durability and heat resistance with aramid reinforcement.
-- Robust Reinforced Tooth Jacket. Durable nylon fiber provides extra wear resistance, doubling tooth strength.
-- Super Strong Tensile Cord. Added strength comes from premium, high-strength glass cords.
Gates Racing Performance Coolant Hoses
The color pops and the performance rocks. What more can you ask from a hose? Get the reliability and performance you demand. Go with Gates Racing Performance Coolant Hoses.
-- Advanced Fiber Construction. Exceptional durability and resistance to pressure extremes.
-- Premium EPDM Rubber Compound. Protects against the high temperatures of full throttle driving. Prolongs the effectiveness of coolant because it's 10 to 15 times more resistant to water permeation than silicone hose.
-- Electro-chemically Resistant ECR® Tube Stock. Combats the leading cause of premature hose failure - electrochemical degradation (ECD).
Micro-V® Accessory Drive Belts
If you want something done right, you have to invent it yourself. That's what we did with Gates Racing Serpentine Belts. You get more than just a cool color. You get high performance, leading edge technology that's 300% stronger with three times the heat resistance of stock belts.
-- Precision Belt Profile. Belts are precision ground, not cut, so they fit the pulley with absolute perfection.
-- Durable, Heat-resistant Overcord. The heat-resisting polyester fabric is reinforced with a patented EPDM compound.
-- Super Strong Tensile Cord. High-modulus, low-stretch polyester means Herculean strength for high load-carrying capability.
-- Heat Beating Undercord. Aramid reinforcement in a patented EPDM compound for three times the heat resistance and durability of standard belts.
-- Specially Engineered Adhesion Layer. Our patented EPDM compound gives Gates Racing belts extended service life.
Applications available for pretty much all Honda/Acura's as well as other many popular manufacturers
Payment methods:
Wire Transfer
Payment methods:
Wire Transfer
Honda/Acura:
D16a1
D16a6
B17a1
B18a1
B18b1
B18c1
B18c5
B18c
B20b / B20z
K20a3
K20a2
K24a
F20c
F22c
H22a4
F23a
Mazda:
B6-T
BP-T
Mitsubishi:
4G63
4G64
Nissan:
SR20DE
SR20DET
RB25DETT
RB26DETT
RB30
RB30ET
VG30DE
VG30DETT
VQ35DE
CA18DE / CA18DET
Subaru:
EJ16
EJ18
EK20
EJ22
EJ25
Toyota:
4AGE
4AGZE
3SGTE
2JZGE
2JZGTE
1UZFE
2UZFE
Payment methods:
Wire Transfer
Re: >>>> ACL Race Bearings - Main, Rod, Thrust >>>>> Gates Racing Hoses and Belts !!!
ACL Race Bearings and a Gates Timing Belt on this 800+ Horsepower Engine
http://www.youtube.com/watch?v=8OUROMHtxV8
gates racing timing belts are a great bang for the buck upgrade -- stronger than OEM with only a small increase in price -- can't go wrong there -- don't spend thousands of dollars on your engine only to put an OEM timing belt on it .
