CEL Problem: Code P0108 Need HELP ASAP.
Old 12-08-2008, 10:21 AM
Agent_EM1's Avatar
Default CEL Problem: Code P0108 Need HELP ASAP.
The Code I get is P0108. Here is what it reads: "Manifold Absolute Pressure/Barometric Pressure Circuit High Input ". I already changed the MAP sensor twice and the guys at the Exhaust/Muffler shop told me it's my Short Ram Intake Sensor (Mass Air Flow Sensor).
I have a 1997 Honda Civic LX Four Door as my daily driver and I recently picked it up. I'm just trying to make a decent commuter out of this car and it is becoming a pain. Any other suggestions are gladly appreciated.
Old 12-08-2008, 10:24 AM
ABK
ABK's Avatar
make sure that tps and map sensor plugs aren't mixed up. Get a voltmeter and some sort of repair manual. It shouldn't take you more then an hour to figure it out.
Old 12-08-2008, 10:27 AM
Agent_EM1's Avatar
Are they almost the same plug?
Agent_EM1's Avatar
Well the MAP sensor I replaced said MAP sensor on it and was on the back of the throttle body / intake manifold. There was a similar looking sensor on the left side.
Old 12-08-2008, 10:28 AM
ABK
ABK's Avatar
They are exactly the same, just check the wires colors on them (the only way to tell)
Old 12-08-2008, 11:04 AM
Agent_EM1's Avatar
Yeah, they're both fine. I have no idea. Do you think the sensor on the intake has anything to do with this? The people at the muffler/exhaust/headers shop I went to told me it could be the short ram intake on my car? They also said it may be the Mass Air Flow Sensor that goes into the intake. YOu think this could be it?
Old 12-08-2008, 11:13 AM
ABK
ABK's Avatar
that's why you don't trust people at the mufler shop, it's not a mass air flow sensor it's intake air temp sensor.
Old 12-08-2008, 11:17 AM
Agent_EM1's Avatar
Thrifty Auto SUpply had another name for it, but i'm gonna pick one up today for $21 or so. Do you think that may be the problem? Man this CEL thing is pissing me off.
Old 12-08-2008, 11:26 AM
ABK
ABK's Avatar
no it's not... It will throw a different code, don't throw parts in the car. I did some research on that code and there is a technical service bulletin from honda for that code. Do you have a rough idle? If you do you need to find out what that TSB calls to do.
Old 12-08-2008, 12:45 PM
Agent_EM1's Avatar
Do you have a link for it?
Old 12-08-2008, 03:08 PM
ABK
ABK's Avatar
just go on google and type in honda civic 97 p0108 tsb. it won't tell you what's wrong but if you got a hook up at the dealer you can find out.
Old 12-09-2008, 09:51 AM
Agent_EM1's Avatar
Thanks... ANyone else?
Old 12-20-2008, 08:05 PM
Agent_EM1's Avatar
So I installed a brand new exhaust manifold (OEM Headers and OEM Catalytic converter) and the shop also changed the bottom O2 sensor and I still have the CEL.... Wow, i'm $800 into this piece of crap and i'm leaning towards giving up. I guess i'm gonna check the wiring of the MAP sensor. Does an aftermarket intake have anything to do with this? All my vacuum lines were good. Please someone help me ASAP thanks.
Old 12-20-2008, 08:43 PM
Christopherian1982's Avatar
Are you boosting?
Old 12-20-2008, 08:50 PM
Paul-R's Avatar
that PO108 code is Manifold Absolute Pressure/Barometric Pressure Circuit High Input
which is build into the ecu , The sensor detects ambient barometric pressure and sends the voltage signal to the microcomputer.
Possible Causes
Harness or connectors (The sensor circuit is open or shorted.)
Engine coolant temperature sensor may be faulty
try checking those.
Old 12-20-2008, 10:58 PM
Agent_EM1's Avatar
Possible Causes
try checking those.
Thanks, I will try that next
Old 12-21-2008, 10:27 AM
Agent_EM1's Avatar
Default Re: CEL Problem: Code P0108 Need HELP ASAP.
anyone else? Does an aftermarket intake have an effect on this?
Old 12-22-2008, 07:49 AM
Agent_EM1's Avatar
ttt
Old 12-22-2008, 04:29 PM
Agent_EM1's Avatar
Help, please?
Old 12-23-2008, 01:58 PM
Agent_EM1's Avatar
up
Old 12-23-2008, 02:32 PM
jelcivic's Avatar
when did this start to happen. if it started when you put the short ram intake on, maybe you left a vacuum hose off. if it isn't a hose then you need to check the map sensor and work your way to the ecu using a volt meter. check hondahookups.com and get the honda service manual and on page 11-121 is where you need to start.
Old 12-25-2008, 09:34 PM
Agent_EM1's Avatar
thanks
Old 12-28-2008, 06:22 PM
Agent_EM1's Avatar
OK I messed with my chords and got a new "before" O2 sensor. Oh yeah, I also cleaned the throttle body and checked all vacuum hoses again and the wiring for the Map sensor and couldn't find anything wrong. So now I have a brand new manifold headers and catalytic converter, brand new BEFORE and AFTER O2 sensors, Brand new Map sensor, Brand new Spark Plugs, Synthetic Oil change, and brand new Air Intake Temperature sensor. Do you guys think it could be the aftermarket intake? Oh yeah, also got brand new exhaust piping at 2" wide and brand new OEM muffler.
Old 12-29-2008, 09:54 PM
Malakai's Avatar
Im having a problem with my MAP sensor as well at the moment. Its winter here now and we get pretty cold. I went outside to start my car, after having the block heater plugged in and it started but the CEL came on. I already knew it was going to be the MAP as this happend 10 months prior. Previously, I changed the sensor twice and finally the 3rd one held. Now it goes out on me again. I really dont see a reason for this to happen.
It was mentioned above that a short could cause this. Now what do you mean by that? Like bare wire grounding itself out, or a loose connection barely making contact?
Also, do you think a sudden rush or too much air during startup would cause this CEL? Such as a leak in the vacuum line going to the master cylinder?
It was also stated to check the coolant temp sensor. How would that have any effect if the code is triggered upon initial startup?
I am very sorry to thread jack, I just want to find clarification as well. The MAP sensor CEL seems to be difficult to diagnose.
Kidnkorner
28
06-26-2010 03:40 PM
DarkBB4
05-08-2005 09:01 PM
TEAM SL
21
08-23-2004 04:04 AM
handa
13
06-28-2004 06:31 AM
jdmrealm
01-31-2002 12:33 AM
Quick Reply: CEL Problem: Code P0108 Need HELP ASAP.
