orange triangle and tcs light help...
Guys, newbie here. please advise im trying to help one of my wifes friends who has a 03 accord v-6 lx(?) she has a warning light on the dash in the shape of a triangle with an exclamation mark in the center, and the tcs indicator is lit on the dash as well. my wife got me into this to try to help a friend out , sure y'all know how that is.... i have scanned it and the code reader keeps saying that the brake level is low.?it has plenty of fluid i checked the connector on the side of the master cyl. but there is no power going to it, all fuses are good- i even checked the emergency brake switch(other than coke spilled on it it was okay)and cleaned it with contact cleaner. and the tcs light does not go on or off with the press of the switch on the dash. also the brake switch on the pedal is new as well. the otrher problem is her power steering is squealing when the car is cold, we put a new serp belt on hoping that would help, but it still sqeals when cold....any ideas / advice is appreciated. sorry for the noob ?'s did a search but not clear as to what to throw at it next thanks Britt
The orange triangle with the exclamation point is the TCS Activation Indicator, and the other is the TCS indicator. When both are on, it means there is a problem with the traction control system. There is no easy DIY fix. I wasn't able to locate any known Honda Technical Service Bulletin for this model year related to any common problem with the TCS.
Regarding the belt squeal when cold, if the belt has been changed, then it can possibly be that the belt tensioner may need to be replaced.
you are not able to purchase it separate from american honda you have to purchase the entire brake mastercylinder and reservoir as one unit.
Guys,thanks for the ideas....she has had the master cyl replaced(?) so she says....is it possible to reach the switch by reaching into the resivour? or maybe pump the fluid out to get to it? by the way , the car only has 67000 miles on it. seems early for brake tcs issues, as well as a worn belt tensioner. although i will check that out. she is original owner of car also. thanks again, keep the ideas coming. I'm better on antique volkswagens (1969) than i am on these computerized newer cars.
#1 fix. if your car is still under warranty bring it in and tell them to change the modulator/abs control unit. if not, your looking at some big bucks.
#2 fix. your power steering is making noise when cold because the o-ring on the power steering pump inlet pipe is sucking in air. replace this o-ring. bleed the system.
Re: orange triangle and tcs light help...
* Remove the brake fluid completely from the reservoir. With the float down, there should be continuity.
* Fill the reservoir with brake fluid to the MAX (upper) level (A). With the float up, there should be no continuity.
Which wire should show voltage on connector? I see blk and grn/red. Also if you know of instructions on how to replace the master and bleed it properly let me know.
#1 fix. If your car is still under warranty bring it in and tell them to change the modulator/abs control unit. If not, your looking at some big bucks.
#2 fix. Your power steering is making noise when cold because the o-ring on the power steering pump inlet pipe is sucking in air. Replace this o-ring. Bleed the system.
I also have the triangle with explanation mark come on first thing when I turn on my car followed by a TCS light afterwards. Both stay on solid. This all happened when I took my car to a local car shop and had my Condenser and AC lines replaced. They claim that they and to remove the battery for access. When I took it back to the shop they said that they called the dealer and that the dealer would have to "reprogram" the ECM. Anything that I can check before I put myself at the mercy of the dealer? I know the dealer want over $100 just to reun diagnostics.
Problem solved. The shop disconnected the battery and long story short they did a tcs pressure sensor neutral position memorization. TCS light and triangle with explanation mark is gone.
Big letters say: do not press the brake pedal.
I left the pins jumped (connected), turned the key, ABS light was off, I pressed "TCS off", then ABS light was on, again I pressed the "TCS off" button and nothing happened... ABS began to blink error 84 again.
I tried to jump pin 9 with just ground, but nothing changed...
RESOLUTION:
But few days ago I have fixed the problem myself without Dealer Scanner!
First of all you need to clear ABS errors (that is the main problem why i have failed earlier).
1) Jump pins 4 and 9.
2) Press and hold the brake pedal and switch on the ignition.
3) Wait for the ABS light to turn off and then remove your foot from the brake pedal.
4) Wait for the ABS light to turn on, then press and hold the brake pedal again.
5) ABS light should turn off, then remove your foot from the brake pedal.
6) Wait for two flashes of ABS light. If it flashes it means that errors are erased.
Check the errors (with the pins jumped) - just turn the ignition on, if ABS light does not flash, no errors are in memory.
Now the main part.
TCS neutral position setting
Do not touch the brake pedal anymore.
1) Jump pin 9 to 4
2) Turn the ignition on, after ABS light turns off, quickly press the "TCS off" button.
3) After ABS light turns on again, quickly press the "TCS off" button.
4) Now shoud be a lot of different blinks and fashes and all lights ABS, TCS and triangle should turn off. The problem's solved.
5) Open the beer bottle!
RESOLUTION:
Now the main part.
1) Jump pin 9 to 4
The following 2 users liked this post by hondahybrid84:
RESOLUTION:
Now the main part.
1) Jump pin 9 to 4
RESOLUTION:
Now the main part.
1) Jump pin 9 to 4
[QUOTE=hondahybrid84;50820545]Big letters say: do not press the brake pedal.
RESOLUTION:
Now the main part.
1) Jump pin 9 to 4
5) Open the beer bottle![/QUOTE
Are you referring to the obd2 pins being jumped??
RESOLUTION:
Now the main part.
1) Jump pin 9 to 4
[QUOTE=Eric Thome;52067722]
You’re a legend. The computer guy could not clear it with his computer and I fixed it with a wire! Thank you so much for the corrected instructions 😊
RESOLUTION:
Now the main part.
1) Jump pin 9 to 4
[/QUOTE
RESOLUTION:
Now the main part.
1) Jump pin 9 to 4
[/QUOTE
just wanted everyone to know, had triangle. the bottom portion worked. I too had to do it 5 times to get it right. i think i miss understood ignition on. initially i was starting it, not just on. thank you. the thread that keeps on giving!
RESOLUTION:
Now the main part.
1) Jump pin 9 to 4
RESOLUTION:
Now the main part.
1) Jump pin 9 to 4
AZNBIGPIMPN505
16
02-10-2005 11:00 PM
